My Walbro 400 Stalls out!?
Old Dec 28, 2011 | 01:58 PM
5LEEPERISAH23I's Avatar
Im on E85, i was tuned for a walbro 255 and it ran n idled great. I put in the walbro 400 in it idles at like 12.0- then shoots up to 17 somthimes. it holds idle then stalls itself out. WHEN I TRY TO MOVE IT STALLS OUT! is that is that tune related or install problem
Old Dec 28, 2011 | 02:54 PM
D Grade's Avatar
Sounds like you might be over running the stock FPR. I had similar problems when I recently rewired my mod'd Walbro 255lph (pulled all that back out until I get an AFPR). If your Walbro 400lph is rewired, then you are definitly over running the stock FPR.
I would yank it and double check everything. One word of advise coming from someone who's installed "a couple" of fuel pumps, double check the o-ring seating ontop of the fuel pump as well as the black plug on the side of the housing. If the o-rings arent seated properly, either the car won't start or you'll have similar issues to what you've mentioned.
Old Dec 28, 2011 | 04:06 PM
what is a good FPR to use. I was looking on extremepsi.com n they all look different some are 25-65psi others 75-90 psi
my mods are in my sig could u lead me a hand
Old Dec 28, 2011 | 04:54 PM
drb's Avatar
drb
Like D Grade said double check everything in the install. If the black plug on the side of the housing is reversed 180 degree's the car will barely start and won't stay running (or so a "friend" told me!).
I installed the Walbro 400 and the adjustable FPR at the same time so I'm not sure if the Walbro 400 will over run the stock FPR, but if your fuel pump has been rewired directly to the battery I would think that it would.
I like the Aeromotive A1000 FPR and I bought mine from Tom at TSCOMPTUNED.
Regardless of which FPR you get, you will want to set your base fuel pressure at 43.5 psig (42 to 45 is ok) with the vacuum line removed and crimped off. You will need a FPR that rises on a 1:1 ratio with boost, so for example with 43 psig base pressure your fuel pressure at 30 psig of boost will be 73 psig.
Dan (drb)
Old Dec 28, 2011 | 06:17 PM
Dan (drb)
im getting a fpr tommorow but now my mini battery is dead n the car is stranded not at my house
but you can hear the fuel pump turn on n prime switch makes me thing it is nothing with the pump
Old Dec 29, 2011 | 08:06 AM
dsmbruno's Avatar
off topic, but how much whp are these walbro 400 good for on E85?
Old Dec 29, 2011 | 10:24 AM
drb's Avatar
drb
I'm guessing close to 650whp on a dynojet & E85, but time will tell. My car will only make a little over 500whp so I'm confident that the 400 is going to be a good choice for me. I still need to get the car tuned with the new FP & FPR.
Old Dec 29, 2011 | 12:26 PM
D Grade's Avatar
Drb broke it down. I personally like aeromotive fpr's and the Fuel Lab fpr's.
Old Dec 29, 2011 | 08:33 PM
jonzie04's Avatar
Stm just made 570 on their dyno and 2150's. Enough fuel for 137 trap speed in a full weight car.
Old Dec 30, 2011 | 05:14 PM
D Grade's Avatar
STM sells Fuel Lab AFPR's so that could be the one they use on their Evo.
rs03evo
Apr 25, 2014 06:13 AM
MaxKanisha
12
Dec 20, 2011 08:32 AM
evo4life400
Mar 13, 2010 01:25 PM
Bigjoeski05
Lancer Engine Management / Tuning Forums
17
Oct 18, 2006 12:25 PM
arpad
19
May 23, 2004 12:46 AM
