HELP!! Suction pipe leak
Old Oct 7, 2003 | 08:19 AM
raywong's Avatar
I discovered a 1cm long crack on the suction pipe between the MAS and the turbo. Would this cause any problem? Do I need to replace it?
Could this be the reason why my max boost comes very late at 4800 rpm?
Old Oct 7, 2003 | 10:00 AM
raywong's Avatar
any comment please?
Old Oct 7, 2003 | 10:13 AM
Trustz's Avatar
I do not think thats the reason for your max boost comes at 4800 rpm, but it may cause some air/fuel mixture problem, because you said the crack is between the MAS and turbo, so you will get more air beside the air flow though the MAS, MAS did not know you have a leak, and actually you got more air in !! just use a tape or something cover the crack and try running the car to see if it make a difference !! let us know.
Trustz
wowzers
Dec 15, 2014 12:41 PM
kiddevo
Nov 13, 2006 05:04 PM
TURBODAWG
May 25, 2005 05:11 PM
evodave
16
Sep 2, 2004 06:14 PM
xstang
May 28, 2004 08:26 AM
