Air Intake - Silicone Vs alloy pipes.
Old Dec 8, 2014 | 03:45 AM
wowzers's Avatar
Hi guys,
please provide your thoughts with the above mentioned suction pipes.
Recently i had been advised that Silicone suction pipes perform better than Alloy suction pipes.
The reason being, the silicone is less prone to heatsoak and that the alloy suction pipes cause vibration, tricking the Engine/ECU in thinking that its Pinging.knocking at high boost levels.
Whether this is true, I'm not sure but i hope someone can shed some light on this.
I currently have an AGP suction pipe (which had been causing dramas for me from day one due to its height/shape for the compatibility with air boxes etc).
replacing an alloy suction pipe to a silicone, to me feels like a downgrade.
All thoughts welcome.
Cheers,
Old Dec 8, 2014 | 05:54 AM
Tuxevo's Avatar
Draw back to silicone: can collaps under boost.
Draw back to metal: reverberation can confuse maf
Old Dec 8, 2014 | 11:42 PM
kikiturbo's Avatar
I have had so much trouble with the steel intake pipe we ditched it and went back to oe rubber one.. fueling at idle was all over the place
Old Dec 9, 2014 | 07:41 AM
mrfred's Avatar
benefit of silicone for afr/idle is only for evos running maf. sd conversions are better off with a big-*** aluminum intake.
i've not heard of any confirmed cases of collapse for silicone evo intakes. i'm making 535 whp without issue. can't go a whole lot higher than that on maf without giving up substantial power due to maf restriction.
Old Dec 10, 2014 | 03:10 AM
wowzers's Avatar
Care to elaborate a little to what you had found?
Yes i am still running the OEM MAF.
i wonder if i was to exhaust header wrap the intake a little, whether it would benefit.
Old Dec 10, 2014 | 05:09 AM
kikiturbo's Avatar
I had a thread started...
https://www.evolutionm.net/forums/ev...le-issues.html
Old Dec 13, 2014 | 09:23 AM
evolvedevo91's Avatar
Only reason I could think of that silicone would work better than alloy pipe for an intake is transition of air.
Smother transition = more fluid air movement
Old Dec 13, 2014 | 02:17 PM
wowzers's Avatar
Yeah but aside from the weld joint, the internal of the pipe of the alloy ones are pretty smooth?
Silicone hoses cost almost the same as alloy ones I had noticed
Old Dec 15, 2014 | 12:41 PM
I disagree I built an aluminum pipe intake for around $30
siliconeintakes dot com
CristianRO
Nov 27, 2017 07:23 AM
kevinlubitski
May 12, 2011 06:44 AM
Bramage_Dained
Apr 12, 2011 03:04 PM
Jorge T
16
Jun 2, 2009 04:29 AM
Vivid Racing
May 2, 2008 11:48 AM
