SKUNK2 PRO SERIES 68mm TB
Old Jun 27, 2009 | 09:38 PM
MR.06MR's Avatar
Im looking at the skunk2 pro series 68mm TB. has any one ever used this and does any one know if it leaks? I have to have one that will mount up to stock mounts and this is the biggest TB that will mount up to the stock mounts. I dont really want to ship off my core and wait for it to come back or front the money till i get a refund to get it milled and ported.
Old Jun 27, 2009 | 09:56 PM
EvoDan2004's Avatar
putting on a bigger tb without port matching the manifold is pointless. either do it right or dont waste your time.
the skunk2 t/b is known to leak real bad. i heard a rumor that skunk2 did a recall and fixed the issue. but i dont know if thats really true or not or if they even fixed it since no one has reported about one not leaking.
also boomba racing makes some sick bolt on T/B's
Old Jun 27, 2009 | 10:03 PM
MR.06MR's Avatar
I have a maguns street intake mani set up for a stock TB
Old Jun 28, 2009 | 07:05 AM
EvoDan2004's Avatar
ok so have it port match then. again stock or aftermarket mani without a port match to the t/b is not ideal.
Old Jun 28, 2009 | 07:21 AM
chaotichoax's Avatar
I never saw one good review about that throttle body
multiple members said it leaked
Old Jun 28, 2009 | 12:03 PM
Kracka's Avatar
Pile of crap IMO. I dyno-tested one for Skunk2 and the thing was garbage. It wouldn't idle and it leaked a lot of air. Then they gave me a hard time about returning it and kept claiming it was "fine" and the leaks were "normal" and I just needed to gob some RTV on it; yeah right, this isn't a rusty 1992 Honda Civic. Go with a 65mm ported unit, they aren't as sexy looking on the outside, but the insides are quality and they're proven to work time and time again. I personally opted for the Mil.Spec.
https://www.evolutionm.net/forums/se...body-junk.html
Old Jun 28, 2009 | 12:05 PM
Cali2MDevo8's Avatar
Registered User
Yeah, go with the Mil Spec unit.
Old Jun 28, 2009 | 12:18 PM
TTP Engineering's Avatar
Any other options available that use the stock idle air controller?
Old Jun 28, 2009 | 12:22 PM
Kracka's Avatar
You don't like the 65mm ported ones?
Old Jun 29, 2009 | 05:32 AM
Boomba Racing's Avatar
Our 75mm TB uses stock TPS and idle controller.
https://www.evolutionm.net/forums/ve...ml#post6870428
foxbat
20
Jun 3, 2014 03:59 PM
jaredh
Jul 4, 2013 11:26 AM
Boost_Inspired
74
Nov 16, 2012 03:38 PM
importdps
32
Nov 6, 2012 09:16 AM
Dan@Assaultech
Evo 'For Sale' Engine Internals and Drivetrain
51
Aug 6, 2010 10:56 AM
