HTA Green vs. BBK
Old Aug 12, 2010 | 09:30 AM
  #226
Jeff_Jeske's Avatar
Originally Posted by cij911
I'll be posting a review of the BBK vs. HTA Green soon (same car, same conditions, etc.). Just looking at the reported flow ratings the turbos I suspect I will see 40 - 50 whp more with the HTA Green. What will be interesting is reporting on the 'transient response' as that is something a dyno cannot answer.
I'm very interested in the transient response as well.
Old Aug 12, 2010 | 10:57 AM
  #227
cij911's Avatar
Originally Posted by sparky
Cij: Sorry to hear about your BBK's untimely exit. Will you be using the FP oil feedline upgrade on your new Green? Also, which compressor housing configuration will you be going with? Good luck
Absolutely and I'll be using the larger compressor housing (84mm ??). I personally believe (as Robert has documented) that the oil pressure can be an issue for stock framed turbos pushed to the ~30+ psi range. Maybe that is why my BBK died....
Old Aug 12, 2010 | 10:01 PM
  #228
sparky's Avatar
With the big cover, and once you install the Kelfords it should be a beastly ride! Will you be going to speed density and a 4" intake? Are you still on the stock clutch, though? Whatever, good luck!
Old Aug 13, 2010 | 02:50 AM
  #229
RockmanX's Avatar
SPARKY I GOT some nice reading material for you to chew on boss pmed
Old Aug 13, 2010 | 06:41 AM
  #230
cij911's Avatar
Large Intake - Yes
Speed Density - Possibly
Clutch - ACT (no lockout on mine)
Cams - May sell my Kelfords and keep stock
Old Sep 2, 2010 | 10:23 PM
  #231
EvolutinIX's Avatar
So on Fp's site it says conversion to the hta green is $869. If I want the 84mm housing is that an additional $150, oil line $150 and porting $100? So for a pimped out ported green, I'm lookin at $1270? Is this correct or is any of the above included? Bbk full ported is gonna be $1350?
Old Sep 2, 2010 | 10:28 PM
  #232
McLaren F1 2003's Avatar
^^^dont forget youll need a larger intake pipe
Old Sep 3, 2010 | 06:49 AM
  #233
cij911's Avatar
Depends on what you have currently....Most 3" intakes will work fine with a 3" to 3.25" coupler....
Old Sep 3, 2010 | 07:30 AM
  #234
06MRV8Killer's Avatar
Your about right on the HTA Green converstion, that is assuming that you dont have a cracked back housing and if you do you will have to source or buy a new one. Go on their site to read about it before shipping your turbo out to them to save yourself a headache.
Old Sep 3, 2010 | 06:14 PM
  #235
EvolutinIX's Avatar
Talked to Fp today and the upgraded oil line is actually $250, plus an 18 psi waste gate actuator for $130, were up to $1550 now for the conversion...
Old Sep 3, 2010 | 06:37 PM
  #236
06MREvo's Avatar
^^that sucks...I would just wait for the BBK-B then...
Old Sep 3, 2010 | 07:29 PM
  #237
EvolutinIX's Avatar
That's what im thinking...on a side note can the stock bottom end hold the hta green or bbk b?
Old Sep 3, 2010 | 08:17 PM
  #238
94AWDcoupe's Avatar
install kit if you had 8 turbo is 250. it includes all parts to install 9 style turbo on a 8 car. includes the 150 oil feed line/filter.
Old Sep 3, 2010 | 08:47 PM
  #239
cij911's Avatar
Guys - the FP is cheaper apples to apples...you don't NEED to get a better WGA....You don't NEED to get a different intake...You don't NEED to get the larger compressor housing.
You should get the upgraded oil line though....And if I had a BBK I would get the FP oil line based on FPs data....
Old Sep 3, 2010 | 09:03 PM
  #240
EvolutinIX's Avatar
Don't need the kit just the oil feed line, but fp said now the price went up to $250 from $150. Could do without the actuator but it seems as though the compressor housing is a must. Can the stock bottom end handle this turbo?
