HTA Green vs. BBK
Absolutely the stock motor can handle the HTA Green - as long as you don't go nuts with boost and torque. I will likely have a lower initial boost and then gradually increase boost - have slightly less torque in the lower rpms. The rule of thumb is to keep torque under 400 - 450 ft lbs (the lower the better for engine stress).
Sure, lol, because I can't find anyone that I trust to install them...I know that is silly, but it is true....I spoke to GMG - the guys that do work on my euro cars - and they did not give me the 'confidence' I need....There are two shops that are ~1 1/2 hrs away, but then I'd need to get a rental car b/c I can't ask a friend or wife to drive 3 + hrs...Honestly just a PITA...
Yes, I have thought about doing the cams myself....
So I am kind of torn here between the new BBK-B and the Green 73HTA. Just based on flow rates alone the Green seems to fit my plan. But if the B has similar spool and transient response then why not have a few extra ponies with room to grow with 5 more lb/min of flow? And quite honestly, CBRD's customer service and the fact they are literally 59.5 miles from my house has a LOT to do with my final decision. I just hope we get more results from both of these turbos over the next few months. Cij911, looking forward to your write up/comparison of the Full and Green.
Question... I bought my evo 8 3 years ago with the original FP green already on.
Im gonna order the HTA green this month, would I still need to order the install kit even though I already have an FP turbo on the car?
Yes but only the install kit for the IX since you have the water and oil lines for the IX compressor housing, not the VIII (saves you $100). You have to do the upgraded oil lines and pressure regulator to go with the newer steel bearings in the HTA73. You could do BBK Full and not have to though.
I get the early Greens mixed up with the Buschur Racing 20G's. Does anyone else remember that turbo? Maybe there never was an VIII-Green( but there was a BR VIII 20G). In which case the OP would not need the install kit.
