Wheel hop launch, now I'm binding/popping on turns (help diagnose)
Old Jun 28, 2009 | 10:53 AM
neonglh's Avatar
Yeah, as the title explains, I was at the track, and I had a terrible wheel hop launch. I didn't know what happened, and I didn't get out of it in time. I didn't think anything was wrong, so I did my pass, went 12.4 @ 115 letting off, with a 1.9 60', and then when I turned at the end of the track to return to the pits, my car was binding, popping, and making HORRIBLE noises. I looked and saw grease all over the engine bay, so I thought I destroyed the CV joint.
I bought 2 low mileage axles, replaced both of the front axles, since both front axle CV boots came apart and grease shot off, and put those in. I went to drive the car around my drive way to see if it fixed it, and it still made the binding / popping noise. My friend was watching and noticed that when I was turning right, my left wheel was almost dragging, and not spinning freely. It was as if I had a spool, or something. At this same time, it basically ripped the steering wheel out of my hand and the steering wheel turned hard to the left, probably because the drivers wheel was not spinning.
So, I was thinking/hoping that it was just a broken axle or 2 from the INSANE wheel hop that I had, but it looks like it is worse. Does this sound like a transmission or transfer case problem?
I have a buschur bushwacker transmission, stock '03 transfer case, and a exedy triple cerametallic clutch. The transmission has about 1300 miles on it, and the transfer case has I beleive 82,000 miles on it. I am almost sure it is the OEM one.
Please let me know what this sounds like, so that I can get the correct thing repaired. Thanks
Old Jun 28, 2009 | 10:59 AM
apagan01's Avatar
Originally Posted by neonglh
My friend was watching and noticed that when I was turning right, my left wheel was almost dragging, and not spinning freely. It was as if I had a spool, or something. At this same time, it basically ripped the steering wheel out of my hand and the steering wheel turned hard to the left, probably because the drivers wheel was not spinning:
you almost answered your own question but you barely missed the answer
03 have this issue by nature, is your TC diff, your spidder gears have stripped,
300$ will fix that sending it to Shepp he will put new spider gears in there, and reshim everything for you.
remember keywords, you were turning the inside wheel was dragging, that means your diff is gone
Old Jun 28, 2009 | 11:03 AM
Clutchdc5's Avatar
03 have this issue by nature, is your tc diff, your spidder gears have stripped,
300$ will fix that sending it to shepp he will put new spider gears in there, and reshim everything for you.
Remember keywords, you were turning the inside wheel was dragging, that means your diff is gone
+1
Old Jun 28, 2009 | 11:05 AM
apagan01's Avatar
look i even went out of my ways to find out shep's web site for you
http://www.sheptrans.com/transcase/evo.htm
you will be looking at STAGE 1,,, thats if everything else is in good condition
or see if you can get an RS front diff and get it in there your self and save some cash,, i doesnt have to be an RS diff, any diff that fits your TC used or new for a good price
Old Jun 28, 2009 | 11:15 AM
neonglh's Avatar
That would be great if it was just that. But just to clear up what you said, my OUTSIDE tire was dragging, not the inside one. I was turning right, and my drivers side tire was the one dragging. Hopefully that does not change the diagnosis at all. Either way, I was praying it was not my new transmission, and that it was something easily fixable.
The next question, do you think the wheel hop caused the problem, or did the problem cause the wheel hop? I never felt anything like this before, and I drive the **** out of this car!
Either way, let's hope the transmission is fine, it's just something rebuidable in the TC, and that I can be up and going again shortly!
--mark
Old Jun 28, 2009 | 11:19 AM
apagan01's Avatar
--mark
there you go, the outside tire drageed
they say that wheelhop is really bad on your TC and car overall.
GL
Old Jun 28, 2009 | 11:22 AM
neonglh's Avatar
Thanks for the help, this is exactly what I was looking for. I will be back up in no time
Stupid cars
Old Jun 28, 2009 | 11:27 AM
apagan01's Avatar
Stupid cars
its ok,,, its all part of this game.
GL with the fix
and God bless
XxApollynxX
Oct 17, 2010 02:28 PM
Xearo
10
Aug 24, 2010 06:52 PM
Darkn3s
Jul 9, 2010 10:01 AM
neonglh
Aug 18, 2009 08:59 PM
CGroovy2k2
28
Nov 26, 2008 07:28 PM
