Turbo Evo 9 80 series
Old Jun 28, 2009 | 11:11 AM
Danieln's Avatar
Hi guys,
Can you please tell me whats the difference between evo 9 80 series turbo and 70 series turbo?
I know that with cams 80 series will do without any problem 420/430 bhp on 1.8 bar.
Also seems that IX 80 series is very reliable and will make more power than most consider safe on a standard bottom end.
The 80 series is maxed out at 440 bhp at max but 70 series I really don't know.
I will run 280 GSC cams soon and I want to learn more about the evo 9 stock turbo proprieties.
My series turbo terminations ended with 14580 but I don`t think that this is the number to look for what type of turbo i have.
Can you please tell me more about those two types of turbo?
Thanks
Old Jun 28, 2009 | 03:46 PM
Danieln's Avatar
nobody??????
Old Jun 28, 2009 | 11:34 PM
Yogi_B's Avatar
80 series is the regular GSR turbo, which comes with the inconel exhaust wheel and aluminium comp wheel.
The 70 series is the one they used on the RS which comes with the titanium exhaust wheel and magnesium comp wheel, this series had problems with the comp wheel coming apart and the comp wheel was redesigned and comes under the 71 series part number.
There should be a series of numbers, yours should have 01580 on it, this means you have the 80 series.
Old Jun 29, 2009 | 02:05 AM
Chamama's Avatar
The 70 series and 71 series are super fast spooling turbos, but both of these series also blow up super fast! I have blown one 70 series at stock boost, one 71 series at 24 psi, gave my friend another 71 series which blew at 24 psi, saw another 71 series blow at stock boost level. I would never ever buy one of those turbos again.
I have tried FP white, which spools quick too and has good top end, and right now I am running BBK Full, which spools about 200-300 rpm later than the white, but has much better top end pull.
Old Jun 29, 2009 | 02:15 AM
Danieln's Avatar
So 70 series is off the GT or RS versions and spools up quicker......but 80 series makes slightly more power....right?
Old Jun 29, 2009 | 02:24 AM
Danieln's Avatar
In order to be on a safe zone with my engine...........with my 80 series turbo , 750cc injectors, walbroo 255 , GSC 280 cams I will be able to pass 400 Bhp?
Currently without 755CC injectors and cams I have 1,5 bar(24psi) with TBEC set at 0
billyboy1
09+ Ralliart Show and Shine
169
Feb 25, 2016 10:28 PM
raytrix
Feb 17, 2009 08:15 PM
HAMMERS
For Sale - Cars For Sale
11
Dec 26, 2008 02:21 PM
spdrcr456
Nov 14, 2008 08:11 PM
Michael K.
18
Jun 5, 2007 01:42 PM
