spark plugs
Old Jun 30, 2009 | 06:05 AM
bbyevo8u's Avatar
spark plugs
i just got stock ngk plugs they come pre-gaped at 21, should i gap them a little more like "24-26"???
Old Jun 30, 2009 | 06:50 AM
Toxin's Avatar
Judging from your signature, you have an evo 9, meaning you bought stock ngk iridiums which come properly pre-gapped... You shouldn't try anything with it or you'll probably destroy it.
Old Jun 30, 2009 | 08:58 AM
bbyevo8u's Avatar
bump!
Old Jun 30, 2009 | 11:49 AM
bbyevo8u's Avatar
i'm putting in the plugs today cause i'm getting a retune tomorrow, should i re-gap or leave them at 20-21???
Old Jun 30, 2009 | 11:54 AM
Macaroni's Avatar
Did you not read that guys reply? If you have a evo 9 then you should have iridiums. You don't gap iridiums unless you feel like buying more.
Old Jun 30, 2009 | 12:04 PM
AWD_Terror's Avatar
I guess they are gapped to that for a reason, but I think that is a crazy tight gap.
You are not going to see any effect likely from either setting. Maybe tighter you might burn up plugs quicker, but doubtful.
for ref I keep mine at 24. They were a little wider open at like 36 (which i think was spec/ but still seems wide IMO) and i was blowing out spark and sputtering a little.
Old Jun 30, 2009 | 12:28 PM
bbyevo8u's Avatar
you dont gap iridiums plugs why not?? lol
Old Jun 30, 2009 | 05:08 PM
Macaroni's Avatar
The iridium tip is fragile and you risk breaking it off if you try to gap them.
Old Jul 1, 2009 | 03:48 AM
Toxin's Avatar
You have an 8, he has a 9.
Think before you post. So much misinformation getting posted because of minor ignorance.
Old Jul 1, 2009 | 06:37 AM
bbyevo8u's Avatar
i left them the way they are at 20-21 gap! the plugs i had in that i replaced i gaped them at 24-25, but the car drives the same with the 20-21 gap?
Old Jul 1, 2009 | 08:59 AM
barneyb's Avatar
Spec is 28 to 31for an 8. Stock NGK Iridiums out of the box are gapped a tight 28.
Old Jul 1, 2009 | 11:31 AM
AWD_Terror's Avatar
Cmon dude. Seriously? lol
Actually there is a post on here about plugs on a 9 and I believe they said spec was 24-25 too. Im sure there cant be that much of a difference in spark due to the all mighty MIVEC.
You need to relax a little bit. My point is they were gapped like that prob for a reason, but will very likely not make the slightest bit of difference.
But what do I know. I run $1.25 plugs in my car that I gap myself.
