Amsoil Intake Air Filter Review
Old Jul 2, 2009 | 08:08 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
I have an amsoil filter sitting in my trunk with a Vibrant MAF adapter I just have to mod my intake tube do i can fit the filter in the engine bay right now having it in the car it won't clear the ACD resovior
Old Jul 2, 2009 | 08:13 AM
BenJ's Avatar
Did you get the 6" on (model# 4560)? What intake setup are you running?
Old Jul 2, 2009 | 09:51 AM
apagan01's Avatar
Originally Posted by Bobster22388
Yea, I'd like to see the pressure drop measurements also, looks like the only difference really is the opening in the end of the filter. I remember when I went to dyno day at CBRD Speedfactory, they found the Perrin filter to be the best one so far, still the filter probably flows better than the Apexi that came on my Evo when I bought it.
the test was not against the perin, it was never meant that way
he purchased a filter from us and he wanted to make sure it was going to yield more power.
Old Jul 2, 2009 | 10:02 AM
apagan01's Avatar
Wow what a great write up, i think without getting to scientific here has been very good for the mayority of the community why because most can understand a simple statement like this write up you have made.
sometimes testing can get so detailed that it will be hard for others to understand
what i mean is that you have shown here how the boost increases at the different RPM ranges and is very clear that the boost was hitting sooner and higher thrue the RPM ranges logged with your gadgets, comparison from the AMSOIL filter over the Injen.
Originally Posted by 04AWDTURBOEVO
I have been using the Injen Air Filters for a few years.
And also getting my motor oil from Andy, http://www.lubedealer.com/order/.
After the most recent motor oil order, the topic of the air filter came up.
I decided to purchase the Amsoil Air Filter, and get it installed right away.
The filter is of very hi quality, and it comes with the clamp an everything to fit the intake fitting.
I was very interested in testing it and finding out if it worked as good as my old Injen filter, so I used some good old tools I have in my car to do just that.
I found out the new Amsoil filter spools the Turbo faster at low rpms, and in the mid range, it made more peak boost. It also maintained the boost more the higher the rpms. Using the super AFC-II, the new Amsoil Filter logged 2276 Hertz at peak boost, and the Injen did 2145 Hertz.
That means that the Turbo was able to suck 130 plus more Hz and feed more air ito the engine.
So I am keeping it, and recommending it to everyone. My comparison shows it is as good or better than the Injen. Very good price, and super hi quality.
My engine is still braking in, so I did not take the rpms much higher than 6900 rpms.
Here are 3 pictures of the logs:
Low rpms
Mid rpms, and peak boost
Hi rpms
Old Jul 3, 2009 | 06:54 AM
apagan01's Avatar
that is exacly what he has
Old Jul 3, 2009 | 09:17 AM
PlanoEvo's Avatar
the amsoil filter is awesome and it filters better than any filter out there while offering just as much airflow. it will clear the acd but you have to tilt it up at an angle. on my ix it works fine but I'm thinking about getting the samco intake and trimming it a little for better fitment and better flow.
Old Jul 3, 2009 | 12:30 PM
Gary@MellonRacing's Avatar
im using this filter , quality is great , looks awesome ,
they smell good to
Old Jul 3, 2009 | 12:41 PM
metal4all6's Avatar
I have one in my Evo & Mazda 6 (the mazda has a CAI). It's a very good quality filter, moreso than the Vibrant filter I bought from Buschur (which you can see through if you hold it up to a light).
The filter just clears my ADC with the ETS intake pipe.
Old Jul 3, 2009 | 12:53 PM
apagan01's Avatar
and if you can see thrue the element of the filtering material,,,, you can come to the coclussion that the filter is not keeping the dirt our of your turbo and your engine internals
Old Jul 5, 2009 | 02:56 AM
crichon's Avatar
Hi Andy,
The filters will come with the clamp ?
Chris.
Old Jul 5, 2009 | 07:43 AM
ROGERV's Avatar
Originally Posted by crichon
Hi Andy,
Chris.
My filter came with a clamp
Old Jul 6, 2009 | 03:37 PM
apagan01's Avatar
Hi Andy,
Chris.
yes sir, they do come with their own worm clamp.
not bad att all
your filters should be on their way this week
Old Jul 6, 2009 | 09:20 PM
ItalyIX's Avatar
Sorry, but what part number for an Evo IX? It also "bolts" right up to the MAF without the need of an adapter to the MAF?
Thanks,
Old Jul 7, 2009 | 05:57 AM
Creamo3's Avatar
I have to agree that this filter is of very high quality. I am actually running a little bit bigger version than most (Model# 6065) and prefer the construction of it over my previous K&N Oiled setup.
Pic of filter:
Old Jul 9, 2009 | 05:05 PM
apagan01's Avatar
Thanks,
Yes sir, it will bolt right up to a 4.5 MAF,,,,, you have pm
