Are the VIII & IX head gaskets the same?
Old Jul 4, 2009 | 11:02 PM
shunderwunder's Avatar
As the title says I need to know it the VIII & IX headgaskets are the same. Thanx.
Old Jul 4, 2009 | 11:18 PM
BLKCarbonEVO's Avatar
NO I'm pretty sure that the IX head gasket has different oil jackets because of the MIVEC head.
Old Jul 4, 2009 | 11:20 PM
That's what I tought. Thanx man.
Old Jul 4, 2009 | 11:29 PM
evoix16's Avatar
No they are the same I have a evo 8 block with evo 9 head and match up no problem fyi mivec has a seperate oil feed from block to the head
Old Jul 4, 2009 | 11:30 PM
Evo209Viii's Avatar
He's Right
Old Jul 5, 2009 | 01:13 AM
I stand corrected, sorry
Old Jul 5, 2009 | 07:27 AM
Not sure what to do now. I had already put the head on the car & when I went to swap the VC gasket I realized it was for an 8. This means the engine gasket kit I have is for an 8. I did a little Googling last night & found theat the 8 &9 head gaskets have diffrent part numbers so I'd imagine that there must be something diffrent between the two.
Old Jul 5, 2009 | 07:29 AM
o7'silvermax's Avatar
if i am correct there is only a small difference and that is a certain port in the gasket but i have used an 8 gasket in my 9 and didn't have any problems
Old Jul 5, 2009 | 07:46 AM
justboosted02's Avatar
they are not the same, however they are interchangeable. the 9 gasket has some revisions to oil flow and also is thicker.
I have an evo 9 block and evo 8 head and I matched the gasket to the head
Old Jul 5, 2009 | 07:50 AM
Mitsutech56's Avatar
Different. The 9 is a bit thicker. If I remember correctly, the 9 has 2 more steel layers. All the holes line up though.
steveyrich
Nov 2, 2016 11:35 AM
meckert
Nov 15, 2012 03:46 PM
blkmkIII
Northeast Region
Nov 23, 2011 01:52 PM
SpecialNeeds
15
Oct 3, 2010 11:36 PM
burchdc
Aug 11, 2007 09:32 PM
