New FMIC worth the money???
Old Jul 5, 2009 | 09:09 PM
evo8john's Avatar
Hey all. I have a 2005 8 with the following mods
3" TBE, Megan Exhaust manifold, MBC at 22 psi, HKS intake, AMS LIP, and a bad reflash ( in the process of solving this myself, only running 3* of timing from 3000 to 6000 rpm)
What would be the next upgrade i should consider. I have been looking at new upper piping and small battery and will probably get that next. Mainly i was just wondering when the stock IC starts costing power and which one will deliver the best gains. my end power levels will probably never be over 500 whp.
Thanks
Old Jul 5, 2009 | 09:29 PM
NsinEvo8's Avatar
255lph pump/ injectors before ic prolly. More boost = bigger ic
Old Jul 5, 2009 | 09:30 PM
joeyhauser's Avatar
if you do get a FMIC i would consider AMS
Old Jul 5, 2009 | 09:38 PM
Buddlight's Avatar
When you start running more boost I would upgrade the FMIC. CBRD FTW.
Old Jul 5, 2009 | 09:48 PM
evoix16's Avatar
Ams or Ets
Old Jul 5, 2009 | 09:51 PM
xRoguex's Avatar
At 22psi ur prob killin ur stock fmic,
I like my BR race fmic some of the best AIT drops and lowest pressure drops.
A fuel pump would be a good idea too.
Old Jul 5, 2009 | 09:54 PM
Evostacio's Avatar
maybe a o2 housing and downpipe or fuel pump before a mini battery if your going for power before show
Old Jul 5, 2009 | 10:00 PM
xRoguex's Avatar
Thanks
DO you have a mail in flash on it?
Old Jul 6, 2009 | 06:18 AM
elijahcole92's Avatar
Fmic should come before uicp and mini battery if your wanting more power
Old Jul 6, 2009 | 08:21 AM
atkins's Avatar
cbrd's intercooler picked me up 29whp and 19wtq, so there is definately power to be made with a good quality core. if you want to do right the first time make sure you use a garret core.
jeff
Old Jul 6, 2009 | 09:02 AM
JakeTheVIII's Avatar
Buschur Racing's intercoolers have been tested to perform time and time again, better than a lot of the competition. I have the ETS though, and I love it.
Old Jul 6, 2009 | 10:04 AM
ETS Michael's Avatar
We always recommend an intercooler if your on the stock unit. Check out this thread.
https://www.evolutionm.net/forums/ev...ts-inside.html
Thanks,
Michael
Old Jul 6, 2009 | 10:21 AM
ScorpionT's Avatar
Yeah, youre in need of an upgrade. Youre going to have heat soak issue, so better safe than sorry.
Old Jul 6, 2009 | 12:03 PM
dambikeracer's Avatar
I saw 29WHP from the Turbo XS IC and Injen Pipes; stock turbo on pump. Then another 79WHP from E-85 with 880's on stock turbo.
Old Jul 6, 2009 | 01:05 PM
l2r99gst's Avatar
I wish I had done more logging and testing, but my 3.5" ETS IC works great on my stock turbo. I was able to add somewhere in the neighborhood of 6* of timing compared to the stock IC. I did add a LICP at the same time though (Nisei).
I'll have to see if I can find some logs from the old IC and the new one to compare for you. But the fact is that an upgraded IC is always a great choice on a turbocharged car, and IMO should be one of your basic mods. Cooler temps = more horsepower and less knock potential. With great companies like ETS providing nice ICs at low prices, I think it's a no brainer.
