whats are these for? (relays?)
I think the one at the top of the bracket is for the fuel pump and the shinny one is for the injectors but whats the last one and what does it do?
and what does the one for the injectors do, shouldn't they just be ground?
-John
The injector relay has a set of resistors in it. They are needed for the peak and hold injectors. If you run Bosch or similar saturated injectors, you have to modify it to eliminate the resistors from the circuit.
evoballer
14
Nov 15, 2019 09:42 AM
Evoryder
21
Jun 14, 2013 05:46 AM
ICE888
Aug 24, 2005 04:16 AM
