Coolant temp gauge?? goin crazy
I will keep this simple.
It did this before and started again tonight when i was the track. it was fine all my runs but my last. anyways, the coolant temp gauge goes up above the H then back down then up again and down and up and down and so on, sometimes it will stay up above the H for long periods of time. on the aem it says its fine at like 178-185 so i dunno what could be up.
i did have a cage installed and pressed through the dash so maybe something got cut or loosened like a ground wire.
any ideas from anyone would be awesome!
thanks and cheers!
thanks and cheers!
I'm sure the cluster came out during the cage install and after that I just don't remember because its been so long. Is there a way to check that temp sensor or should I just take one out of another evo and see if it works?
Thanks!
Thanks!
Tw3NTy0n3
13
Jun 29, 2016 11:09 AM
evodrivesme
14
Sep 24, 2007 10:27 AM
