What Tranney Fluid do you use?
Old Jul 9, 2009 | 07:41 PM
whitey4d's Avatar
Originally Posted by S2kracka
Redline cocktail containing 2 quarts of MT-90 and 1 quart of MTL. This seems to be the perfect combo for Mitsu 5-speed transmissions.
Ive been using basically the same thing. Except Ive put in 2 quarts MT90 and top off with BG syncroshift II. Seems great except when freezing or cold out. Then its a lil thick til a lil heat gets in it.
Ive only been using the BG cause I get it for next to nothing do to knowing a BG dealer. But they dont make a 75-90. Just a 75-80 thats too thin for the gears at high torque loads or shock loads.
Old Jul 10, 2009 | 02:12 AM
Evil_3v0's Avatar
Castrol TAF-X 75w/90 for the trans.
Old Jul 10, 2009 | 03:48 AM
modvp's Avatar
I use 3 quarts of Redline MT-90.
Old Jul 10, 2009 | 03:50 AM
Domolution's Avatar
Eneos FTW!
WEhehe!!!
Old Jul 10, 2009 | 09:10 AM
ladysman's Avatar
I've used Redline mix, OEM and amsoil. The amsoil seems much smoother. i haven't used amsoil yet in the winter time so taht will be the big test really. I'm sure it will be slightly notchy but i'm hoping not as notchy as the other 2.
Out of all 3, the redline was the worse. It was notchy all the time. This is in an 05 MR by the way. The amsoil is also 1/3 the price of OEM.
Old Jul 10, 2009 | 10:02 AM
03blkevo's Avatar
Looks like amsoil, i might have to try that. not one person used the purple drank huh?good to know i was using synchromesh 2 but due to that piece of crap nascar race there was none left in town.
def was loud i will say that i have the exedy twin disc and it rattles but hopefully that gets low quieter with amsoil.
Old Jul 10, 2009 | 10:32 AM
8UpUrV8's Avatar
I ran Pennzoil Synchromesh, and when Jon@TRE tore it apart for a broken 3rd gear, he told me the tranny had alot of damage from that fluid...
Only AMSOIL from there on out.
Old Jul 10, 2009 | 12:59 PM
apagan01's Avatar
Old Jul 10, 2009 | 01:00 PM
Boomer0822041's Avatar
good thread. thanks
Old Jul 10, 2009 | 01:52 PM
Evo8luva's Avatar
I switched from ams oil to redline mt90, noticed a little bit better shifting, but it seems to need to be changed more often, like 6-8k instead of 10k+
I don't mind changing it more often for the super fast shifts I get.
Old Jul 10, 2009 | 06:13 PM
metal4all6's Avatar
Amsoil is some good stuff
Old Jul 10, 2009 | 06:31 PM
Justin VIII's Avatar
ive had BG syncroshift II for a decent run.....but i think i want to use Amsoil from all the positive reviews, however i have not one complain on the BG snycroshift II, my trans has been loads smoother since i switched to BG but i think i might try out the amsoil
Old Jul 10, 2009 | 08:39 PM
ladysman's Avatar
Fluid won't change how the clutch sounds. It's a twin plate so it's "nature of the beast" with those. You will have to live with it. Unless it isn't the clutch making the noise? Does it go away when you push the clutch in?
Old Jul 11, 2009 | 01:48 AM
03blkevo's Avatar
yeah its just the plates shaking together! its so funny when ppl get into the car and get all scared "whats that sounds like something is broken"
Outie11
Outlander Sport
Jun 14, 2019 03:55 PM
4g63t28
Nov 20, 2006 08:32 PM
andyktlee
Northwest Region
21
Nov 4, 2006 04:28 PM
JaReDbOy
Sep 12, 2004 02:29 PM
imemac
Apr 16, 2004 07:14 AM
