Rattling coming from my engine
Old Jul 24, 2009 | 03:34 PM
neonhorse's Avatar
Mine had a weird rattle that i couldnt figure out, and after driving, listening , different rpms, etc, finally put it on a rack and found a branch stuck up above the drive shaft. No idea how it got there.
Old Jul 24, 2009 | 08:26 PM
Jeff_Jeske's Avatar
If you have an old garden hose you can chop it into a 4ft lenght and use it to isolate the source of the noise. Let us know what you find.
Old Jul 24, 2009 | 08:37 PM
huevosrancheros's Avatar
If you have a DP is it a 3incher??? Have you placed spacers on the brace bar underneath??? If so double check to see if the bolts are good n' tight. This was my case, the car woould make a loud noise almost comparable to a heat shield coming loose. The bolts were stripped and not holding the brace as good.
Old Jul 25, 2009 | 05:47 AM
barneyb's Avatar
Originally Posted by Rxracer
Umm, H2o pump runs off the timing belt , but you would loose the rest..
The only accessory the timing belt runs is the oil pump.
Old Aug 10, 2009 | 10:17 PM
RainesEVO's Avatar
I had a mysterious rattle as well. Found it to be coming from the A/C Compressor. Few weeks later the A/C compressor completely broke, leaving the pulley able to move side to side.
fandadar
Feb 5, 2017 06:31 PM
campbmic
22
Mar 4, 2012 08:24 PM
Yousef
Aug 13, 2009 10:16 AM
