Rattling coming from my engine
Old Jul 9, 2009 | 09:51 PM
e v o's Avatar
ok guys... I been having this problem for the past 2 weeks. My car has been rattling like crazy and its pretty loud. I thought it was the DP hitting the crossmember but its not that. ITs coming from my valve cover area. Click on the video link for the sound
Here are the things i have already checked:
- DP hitting the cross member
- turbo fins hitting the housing
-wastegate actuator
-flapper on the turbo
any ideas of what it could be?????
http://www.youtube.com/watch?v=SzPgTuJLiKs
Old Jul 9, 2009 | 10:12 PM
NsinEvo8's Avatar
checked the maf honeycomb?
Old Jul 9, 2009 | 10:14 PM
churbo's Avatar
Notice any driveablity issues with it.
Old Jul 10, 2009 | 06:26 AM
e v o's Avatar
- checked the honey comb - its fine
- drives completely normal - no issues
Its just incredibly loud rattling and wont stop and i can not pinpoint where its coming from.
Old Jul 10, 2009 | 07:30 AM
Hioffcr's Avatar
From: Killeen, Tx via Fayetteville, NC via Worthington, OH
O2 Housing heat shield (this was the source of my rattle), or exhasut manifold heat shield.
Old Jul 21, 2009 | 06:12 PM
SeeCoryRun's Avatar
Sounds like it could be valvetrain. use a prybar/ long screwdriver as a stethiscope(sp*) to help find the true source. put one end on what you want to listen to, and the other end to your ear. where the noise is loudest is most likely the source. keep in mind that noise/vibrations will travel.
Old Jul 22, 2009 | 05:41 AM
mexigun's Avatar
I just had my 60k mile maintenance and when I got my car back I also had a noticable rattle coming from what sounds like the engine or somewhere under the drivers side of the car. I thought they did something to my exhaust because it was noticeably louder above 3k rpms but I think its just whatever is rattling down there that makes it loud. I have no idea what it is...
Old Jul 23, 2009 | 10:28 AM
Rxracer's Avatar
+1 on valve train, pull the valve cover and do a good check.
can you hear the rattle when you drive?
does it seem to go away when mivec engauges?\
Rob
Old Jul 23, 2009 | 10:39 AM
KillaItalian904's Avatar
have you recently had a timing belt changed? the balance shafts can be difficult to synch on time, alot of folks end up putting it back together 180 degrees out which causes some pretty nasty rattle and vibration above 3k RPMs.
Old Jul 23, 2009 | 11:13 AM
Rxracer's Avatar
thats interesting cause i dont know the history of my car and i get a wierd vibration above 4k.. hmm, and my car only has like 43k miles
Old Jul 23, 2009 | 02:11 PM
t-revzr's Avatar
Does it still rattle when you push your clutch in? My throw out bearing rattles and then i just push my clutch in and it goes away.
Old Jul 23, 2009 | 02:38 PM
mexigun's Avatar
Yea I had my timing belt changed with the milage maintenance. The vibration is loud at 3k rpms and very loud at around 5k rpms.
Old Jul 23, 2009 | 04:45 PM
mopevo's Avatar
Check your sparkplugs, it can be that one of them is semi loose. Its happened before, it can make some noise up in the valve cover area. Double check that man, gl!
Old Jul 23, 2009 | 10:17 PM
Asmodeus6's Avatar
My car made a similar rattling garbage noise this morning. And my AC compressor completely seized up by the middle of the day - catching itself on fire and making my day suck.
Check that. Serpentine belt means no AC. No h20 pump, no alty, no ps... nothing.
Old Jul 24, 2009 | 12:09 AM
Rxracer's Avatar
Umm, H2o pump runs off the timing belt , but you would loose the rest..
