Does anyone have an ARC oil catch can installed in their car? Please help.
I have an ARC oil catch can for my car just sitting in my garage and would like to see where each hose goes into. There are 3 fitting holes on the catch can so I'm confused what goes where. This is the oil catch can I have.
I tried to research and asked around how to install this but I still can't get no answer. Please help. Pictures would be helpful if anyone has this catch can.
I have an ARC catch can, I have had it for about a year and yet to have found instructions for it nor a good shot of it installed. So maybe someone will post some type of instructions or a close up of it installed.
Me too...mine has been sitting in the box for 3 years...no directions
I went to ARC website...nothing...they suk
I wish some one could draw up a diagram... I posted a need help on setting up the catch can MANY years ago and no help, so It sat in the box...wasted my money
Thanks 350Z 2 Evo8. What UICP do you have? I have the same ARC intake box and tried to install my ETS UICP and it wouldn't fit. Also can you have a close up pics of the catch can to see where exactly what goes where? Thanks for the help.
Im guessing the big fitting connects to the turbo intake tube to get some vacuum. The other two can be hooked up to the valve cover. One for the PCV and the other side vent.
THe pic posted above shows it pretty clearly if you are on a decent screen on your computer. Basically the two smaller fittings connect to your pcv and breather outlet on your valve cover. I don't think it matters which one. The tab is where it bolts and mounts onto the battery j hook mount. the big line is for the breather to either put a filter on or route it back to the intake like the oem setup is. If you put a filter on the catch can then you would have to cap off the intake tube fitting. Simple as that.
TxFAkuma
Sep 23, 2022 07:47 AM
WTB[MidWest]: WTB ARC Parts; Cash in Hand!
rk7
13
Apr 20, 2017 09:27 PM
EJEvo
30
Oct 24, 2011 10:45 PM
hk2ronin
Feb 14, 2011 04:16 PM
