Is the Mini battery strong enough in the Northern States?
Old Jul 11, 2009 | 04:22 PM
TS8's Avatar
TS8
Searched with "Mini battery", but couldn't find answers.
Just wondering if the mini batteries are strong enough to start the Evo during the sub-freezing winter months up here in the Northeast?
Does anybody actually have any experience with them in the New England area
in the cold?
Any input would be greatly appreciated.
Old Jul 11, 2009 | 04:29 PM
InitialE's Avatar
Is your car normally in a garage during the night?
Old Jul 11, 2009 | 04:31 PM
TS8's Avatar
TS8
My Evo is always outside.
Old Jul 11, 2009 | 05:03 PM
TS8's Avatar
TS8
Anybody?
Old Jul 11, 2009 | 05:05 PM
ak47po's Avatar
I wouldn't do it if it was my DD.I have a mini and i live in Maine,but i have a garage.I also went with stock route uicp so i can put back my full size battery during winter months.
Old Jul 11, 2009 | 05:16 PM
whiptheevo8's Avatar
in the cold?
My odyssey mini battery lasted through the winter here in Breckenridge. I think the only time it took a few tries to crank over was at -12.
Old Jul 11, 2009 | 05:22 PM
TS8's Avatar
TS8
ak47po thanks for the pic, nice idea!
Did you feel a lot of difference after the intercoolerpipe change?
Also, if it can survive Colorado winter, I may consider it.
I 'm in the process of going with Injen pipes, but did not like the way LICP tapers down like stock. Thinking of going with Nisei pipes w/ mini battery in the future.
Thanks guys!
Old Jul 11, 2009 | 06:24 PM
TS8's Avatar
TS8
Anybody else made it through the ice with a mini battery?
Old Jul 11, 2009 | 06:32 PM
Here is my mini battery setup when i had the buschur battery(odyssey) with the buschur ICP.
Old Jul 11, 2009 | 06:45 PM
TS8's Avatar
TS8
Did the Buschur die on you? How long did it last?
I guess the Odyssey is the way to go.
Old Jul 11, 2009 | 07:25 PM
denile's Avatar
Had my Buschur installed for 3 winters.Only had problems when I wouldn't start it for longer than 3 days.It's my DD and has been fine for me.
Old Jul 11, 2009 | 08:29 PM
JohnDoe1984's Avatar
What about the miata battery? I hear it's small enough to clear the short run UICP's but much more reliable than the evo mini battery kits around.
Old Jul 11, 2009 | 08:54 PM
The battery did die. That was only after my alt died and drained it.. replaced the alt it died, and drained it again.. that finally killed a cell. The battery has done very well for me, and the new one is just as good. starts right up no problems.
As far as it being the best i have no idea. You should figure out what kind of space you will be working with. CCA of each battery. Research will be your best idea.
Hope this helps.
Old Jul 11, 2009 | 08:59 PM
erald01's Avatar
best advice is to relocate it in your trunk and is a LOT cheaper than the mini battery, and it will help with the weight distribution..
Old Jul 11, 2009 | 09:01 PM
TS8's Avatar
TS8
denile, may I ask where you live?
So after 3 days w/o driving, the battery died?
Anybody else heard of Miata battery use? Thanks!
