mystery problem! help diagnose
Old Jul 25, 2009 | 11:55 AM
  #31
nikkadanny's Avatar
bump..still dont know what the problem is. i guess im going to take to the dealer and see if the timing belt is on right.
Old Jul 25, 2009 | 12:42 PM
  #32
SupaDoopa's Avatar
Wow. After posting, I FULLY read this and it's about the same thing I'm experiencing. I was actually following all my vaccuum lines and going to replace them and check piping. My CEL came on and stayed solid. I noticed it knocked before it stayed solid and that's when I parked it. I haven't checked injectors or plugs yet, but that's next. Have we not found the solution yet?
Old Jul 25, 2009 | 01:17 PM
  #33
nikkadanny's Avatar
no cel's pop up, the car drives fine but under a lil throttle from 2-4k itll start knocking.
Old Jul 25, 2009 | 01:37 PM
  #34
SupaDoopa's Avatar
So you haven't yet found the cure?
Old Jul 25, 2009 | 01:53 PM
  #35
Nate's Avatar
How did you do the balance belt without removing the crank timing plate? Or does this car not have balance shafts anymore?
Old Jul 25, 2009 | 04:11 PM
  #36
nikkadanny's Avatar
kevind would have to answer that question he did the install i didnt, no cure yet, but i talked to acouple of people and they said its most likely the timing belt.
Old Jul 25, 2009 | 06:24 PM
  #37
project_skyline's Avatar
Ok if you dont remove the crank timing plate you remove the CAS. Its one or the other. If this happened after the timing belt job I agree that its only something affected by it. Try replacing the CAS and see what happens.
Old Dec 24, 2009 | 04:12 PM
  #38
dastallion951's Avatar
if u changed the timing belt id say u must either be off a tooth or the crank sensor maybe was damaged or somethin during reinstallation.....also would double check the spark plug gap, and make sure the plug wires are reinstalled properly....bein that u had a rich condition i would double check since u have access to a scanner, check the air temp n see what its readin, my air temp sensor on mine is reading 107 * and its about 60* outside rigth now....good luck keep us posted.
Old Dec 24, 2009 | 04:47 PM
  #39
KevinD's Avatar
little late... we never did figure out what it was. wasn't the timing belts (as if you read carefully i said we double checked that). after a few days of driving it, it just seemed to go away. possibly a bad tank of gas...
Old Dec 24, 2009 | 06:42 PM
  #40
barneyb's Avatar
Hmmm....a bad case of the ECU doing what it is supposed to.
honda-guy
Oct 10, 2014 05:14 PM
blk-majik
23
Aug 16, 2012 04:20 PM
jameswwt
Jun 20, 2012 10:46 AM
tcarretti
20
Nov 9, 2010 05:21 PM
taenaive
Nov 1, 2009 08:56 PM
