tcase fluid change help
Old Jul 15, 2009 | 11:11 AM
NewEvolutionIX's Avatar
I was told at the mitsu dealership that I need to use a scan tool to change the fluid in my tcase due to the ACD. Is this true?? Or can I just change the fluid and go on my way. I have drained it but have the DIAqueen to put back in.
Old Jul 15, 2009 | 11:37 AM
srtboostin22's Avatar
noooo, i just got done doing this on my 9 ... just drain it, put the drain plug back in..
Crack the bleed screw open, turn the key on but dont start the car,
push the gas pedal to the floor for a few seconds. You will hear the
acd cycle or whatever it does. Turn key off.... You may have to do
it a few times.
^taken from the how to section
Old Jul 15, 2009 | 11:55 AM
PATRICK B.'s Avatar
Only need to bleed acd if the line was removed.
Old Jul 15, 2009 | 05:55 PM
Yeah I did remove the line on the top of the tcase. so im guessing I do have to bleed it
Old Jul 16, 2009 | 10:15 AM
PATRICK B.'s Avatar
In that case yes you do
Old Jul 16, 2009 | 12:54 PM
Kracka's Avatar
ACD and transfer case fluid are two totally seperate things. Transfer case fluid change is as simple as draining and refilling just like the transmission and rear differential. You should be using a GL-5 in the transfer case such as Mitsu DiaQueen 90W LSD (same fluid that goes in the rear diff). The ACD systems uses a Mitsu ATF fluid and must be properly bled and not just drained and refilled. ACD fluid is not considered to be a routine maintenance item though so unless you're having a problem with it or drain it during a clutch swap there is no need to perform this.
ReidFletcher
Aug 31, 2016 10:37 AM
jtcarstens
Sep 18, 2014 07:01 PM
heingtaing
15
Mar 4, 2011 09:12 PM
silverguy
18
Jan 16, 2011 08:23 PM
drocksmash
Northwest Region
Dec 12, 2010 11:43 PM
