Clutch rattles on Deceleration?
oo one note, it use to rattle only from 3000 to 2450rpm in 3er and 4 and 5 gear only, now than i have removed my WR Engine Torque Stiffener cause the metal bracket has been broke is making more noise even in 2 gear from 3000 to 1900rpm, so i will install the WR Engine Torque Stiffener, installing back my oem harmonic balancer and change my motor mounts for Avid billet motor mount after all that it my help!
thats wierd. i'm at the point were i want to take out the clutch and TOB and replace it all lol.
my buddy just went with a comp clutch and ACT streetlite flywheel (same flywheel i have) and he has no rattles or noises. it has me thinking lol
Do you have oem harmonic balancer? RRE they tell me to better use the oem for noise reduction
yeah i"ll probably change the clutch out before it needs to be and see what happens then. just dont want to spend another 700 on a clutch setup. not to mention having to change it out lol
i forgot to mention that i do have a Buschur front motor mount installed. did this along with the clutch change
Have the same thing, same rpms, same gears for the most part. Had it on the stock setup as well, became more noticeable with an Amsoil fluid change (not a dig, awesome fluid). Went to a single organic Exedy installed at CBRD, double checked with Chad, same noise as always just amplified. Gear selection only effects it because of the speed of the gear sets changes the specific frequency, and the vibration gets worse. Don't sweat it bud, just one of the many nuances of Evo ownership lmao.
I have the exact setup (clutch and flywheel) that you have, and also that ******* rattle when I let off the gas. Still trying to figure it out, only things I can come up with are either the clutch or the flywheel. At least I know it's not just my car, I thought we F'ed somthieng up during the install.
I have the same problems with my Evo 2. Have tried both QM twin and Carbonetic Carbon tripple and they both make the tranny sound really bad on deacellaration. It did not make this noise on standard clutch. I believe the reason for this sound are that these clutches dont have a sprung/dampened center. I have also tried to shim up the tranny a little tighter, but still alot of noises.
I believe the only thing to remedy this, is to change to a clutch with sprung/dampened center. That is my personal opinion, not the fact
I have only found one twin plate clutch that have a aprung center, and that are this OS Giken clutch: http://www.osgiken.co.jp/pro_clutch/clutch/r2cd.html
Anyone know about someone that have this clutch and how it performs?
Hey, any updates on this issue? i just changed out my clutch at 106k and its doing the rattle in 4th and 5th gear only on deceleration. i put in a comp clutch lightweight flywheel and stage 2 clutch.
thanks in advance!
thanks in advance!
i get intermitten noise on decel in 4th or 5th, gear, ive always bought the same clutch/flywheel kit done it since i bought the car. IM running act hdss with prolite flywheel. Chatter is somewhat normal. Thats mostly what your hearing is the clutch disc rattling because the pressure plate isnt applying pressure on it. Until the time comes that it wont go in gear anymore, just gotta deal with it. But being over 400 hp couple times down the 1/4 1-4 gears wot on a regular basis, ive got over 40 k on it, no slippage. IF we want quiet shouldve bought a bmw. haha But I gotta admit every passenger has asked what the noise was, my answer its a true race car. haha
