Engine build finally complete, yeah.
After a long while of the Evo being down do to an Intake Manifold Vacum Line poping out on a WOT run, my Engine is now completed and tuned.
Thanks to Procco(Eddie), Felix, and apagan(Andy) for their advise in this long engine building process. They helped me pick and choose the parts, the engine builder, and alot of the things.
Also thanks to Pollo Performance Racing, my Engine Builder for the amazing job he did in putting everything together. From balancing and blue printing, to the custom machine work and fabrication he did on this build.
And Frank at Xtremeboost for his support and advise on many things as well. Thank you for allowing me to look at your work, and learn to do many things on my own, some times using your work tools.
Many thanks also to the Titan Motorsports guys, Mike at AWD Motorsports, the guys at AMS Performance, the guys at Force Performance, the Engineers at Carrillo and CP Pistons, Kami Speed, the crew at Tilton, for the great customer service and price in all the parts. And big Valley Performance for the Dyno facility.
And finally many thanks to Jester Tuning(John) for his amazing tuning work.
The good thing that came out of this is that I did all the tech work, so I now know where every nut and bult goes on in this sucker
Parts used in this engine:
2.0L
CP Pistons 9.0 87mm Titan
Carrillo Pro H rods w/custom bolts Titan
Clevite Main/Rod Bearings including Thrust Bearings AMS
Balance Shaft Eliminator Custom Pollo Performance
ARP Main Stud Kit AMS
Mitsubishi Full Gasket Kit AWD Motorsports
ARP Head Stud Kit AMS
Mitsubishi Timing Package AMS
Mitsubishi Water Pump Kit AWD Motorsports
Mitsubishi Oil Pump Kit AMS
Kelford 272 Cams AWD Motorsports
Super Tech Dual Springs/Titanium Retainers/Guides/Locks AMS
Super Tech N coated valves AMS
BR Dual Fuel Pump Kit AWD Motorsports
BR 65mm TB AWD Motorsports
BR Intake Mani AWD Motorsport
Timing Belt & Assesory Belt Titan
1000cc Pressition Injectors AMS
Intercooler Piping by Xtreboost
Q Valve Titan
HKS DLIII Titan
Tilton C/C Titan
80mm RED Turbo Forced Performance
24psi WGA Forge Motor Sports
SAFC-II Titan
E-01 BC Titan
Valve Cover Jack Rogers Coating
Cometic Fuzion Custom Head Gasket Titan
Front Motor Mount Forge
Fidansa Gears Titan
L19 Head Bolts Titan
LC1 Wideband Innovative
Medallion Touring 80mm Kami Speed
Amsoil intake filter and engine oil 20-50
More things like electronics, knobs, etc.
The car was tuned on pump 93 gas to 458 whp and 419 Tq at 29.1 psi.
On race gas(Q16) it made 558 whp at 36 psi.
I left the graphs at the tuning shop with all the exciment
. I will post them later.
We wanted more, and actually made a run at 39.9 psi, but let off because the car went lean for a moment and knocked. After 4 hours on the Dyno fine tuning the pump and race gas dual maps, it was time to call it done for the night.
We will continue another day, adjusting cams and also adding more timing to the car.
The car rear differential was damaged during the last few pulls. It is running, but the unit will be replaced in a day or two.
Here are some pictures of the initial damage that happened to the engine and Turbine Wheel, and the progress and parts used during the build.
The block and head were perfect if you can believe it.
The last pictures are of the car.
It looks so stock from the out side
Thank you for reading.
Red Wheel Damage
Empty Bay
Block off the car
Piston Damage
BR Dual Pumps
BR Pump Wiring
Ported Exhaust Head Pollo Performance
Ported Intake Head Pollo Performance
Super Tech Valves
BR Ported Intake
Polished Crank
80mm FP RED
BR 65MM TB
Tilton Disks
Ported Ex. Manny
Turbine wheel RED
Pollo Racing Custom balance shaft removal
Assembled Block
Block
Carrillo Rods
Cometic Gasket
CP Pistons
Dual Springs
My favorite, lol. How many zip t's does it take to keep it save. Porky Pine.
The following is of a compression test I did the day after the Dyno. Very nice and even on all the cilinders, 1-4.
The car as it is now, and the engine bay shots:
.Parts used in this engine:
2.0L
Q Valve Titan
HKS DLIII Titan
Tilton C/C Titan
SAFC-II Titan
E-01 BC Titan
Fidansa Gears Titan
. I will post them later.We wanted more, and actually made a run at 39.9 psi, but let off because the car went lean for a moment and knocked. After 4 hours on the Dyno fine tuning the pump and race gas dual maps, it was time to call it done for the night.
.Thank you for reading.
Red Wheel Damage
Empty Bay
Block off the car
Piston Damage
BR Dual Pumps
BR Pump Wiring
Super Tech Valves
BR Ported Intake
Polished Crank
80mm FP RED
BR 65MM TB
Tilton Disks
Ported Ex. Manny
Turbine wheel RED
Assembled Block
Block
Carrillo Rods
Cometic Gasket
CP Pistons
Dual Springs
