1,2,3, and 4th gear synchro's and sliders...is that supposed to look like that?
Old Sep 1, 2011 | 07:03 PM
  #46
corndog17's Avatar
Is there anyway to put a syncro sleeve back on the syncro hub without pulling the gears from the input shaft to slide the syncro sleeve over the springs on to the hub. I recently slide the sleeve down toward the input shaft bEaring and I can't slide it back on the way it came off. Has anyone ever done this and was able to put the sleeve on without pulling thE gears off the input shaft.
Old Sep 2, 2011 | 01:28 AM
  #47
94AWDcoupe's Avatar
the slider is keyed. 6 teeth are taller that the rest. the taller teeth only mate to taller grooves. so yes it goes back on.
Old Sep 23, 2011 | 02:11 PM
  #48
R/TErnie's Avatar
ha.
kpt6
Apr 17, 2013 01:12 AM
zasboy
25
Oct 14, 2012 12:44 PM
