9.8 vs 10.5
Old Jul 17, 2009 | 10:29 AM
stockevo03's Avatar
3500, youl probably see full bost somewhere around 2500 seeing how you have more displacement
Old Jul 17, 2009 | 03:49 PM
Bo'sEvo8's Avatar
The 05 VIII's and Evo IX's have the 10.5 cm hotside its good for alittle more top end power. I had an 04 VIII with a 9.8 and I swap to a 10.5 with other mods to give my car amore flow up top. It still spools the same with more up top power.
Old Jul 17, 2009 | 03:54 PM
Bo'sEvo8's Avatar
I just realized your were talking about your stang. In that case 9.8 might help spool the stang slightly faster but, not by that much. Although with 10.5 you can get more flow to add an additional hp up top where the 9.8 will become restrictive
Old Jul 17, 2009 | 04:43 PM
magyar86's Avatar
I have a 10.5 Hotside turbo and a 9.8 hotside turbo here. PM me on here if you want another turbo, or 2
Quad setup FTW
Old Jul 17, 2009 | 07:55 PM
C6C6CH3vo's Avatar
10.5 will allow more volume at higher rpm so more HP. The 9.8 will just spool the turbine quicker and might have a little more torque. 9.8 will have more backpressure beyond peak VE
Old Jul 17, 2009 | 11:27 PM
NsinEvo8's Avatar
ported 10.5 i see full boost at about 3600
Old Jul 18, 2009 | 08:18 AM
cedes14bamg's Avatar
interesting guys
but then the 9.8 might be better then the 10.5 for a simple lancer right?! depending at how it spins, but if it spins more does it means it creates more heat so then the 10.5 would be better according to that?!
Old Jul 18, 2009 | 08:27 AM
tweaker41's Avatar
Stock IX turbo, 10.5 hotside and full boost (24.5lbs) at 3400rpm
Old Jul 18, 2009 | 12:16 PM
PaperClip's Avatar
Stock 8 turbo with full exhaust (no cat and o2 housing upgrade) i hit max boost around 2900rpm to 3100 rpm its hard to say for sure.
sounds like a cool project. keep us posted.
Old Jul 19, 2009 | 03:13 PM
thats awesome so actually the evo 8 stock turbo gets the boost quicker but like ya all said the evo 9 one gets it all top end. kinda hard to decide which one tho, but some might pick the 10.5 cause its only more new
still kinda think and research
Old Jul 19, 2009 | 03:54 PM
5LEEPERISAH23I's Avatar
Just bought a 10.5 hands down better then the 9.6
Old Jul 20, 2009 | 06:36 AM
okay
dprez25
May 12, 2012 10:33 PM
racer135
19
Oct 9, 2008 09:46 AM
EVO-8-Nate
Feb 8, 2006 06:04 PM
EvoDan2004
25
Dec 1, 2005 09:52 AM
