QTP Downpipe Flange hitting driveshaft.
Old Jul 17, 2009 | 01:35 PM
BostonEvo's Avatar
Alright So i have tried every wich way of adjusting the downpipe. The the flange on the cutout itself is hitting the driveshaft. Iv gone threw the forums and had seen that other people had this issue yet i couldn't find how they fixed it.
I might add , That it only happens When i get on it in 1st/2nd gear ( Lots of torque on engine ) So the driveshaft is dipping down. I am on stock mounts.
Would the easyest way around this to be to change out the mounts as it looks like its only hitting by a 1/8 of an inch or so.
Only other thing i can think of is to take a digrinder to the flange and cut it down some but i dont want to worry about leaks.
Old Jul 17, 2009 | 02:40 PM
EvoJoeIX's Avatar
the cutout should be pointing away from the driveshaft...
not towards it
Old Jul 17, 2009 | 02:44 PM
06MREvo's Avatar
^^same thing he said...mine points towards my drivers side door...went on perfect...no problems...I've had 3 different 02 housings on the car too...stock...megan...EPM...no problems with any of them...
Old Jul 17, 2009 | 03:49 PM
BostonEvo's Avatar
Flange does point towards the Drive side door , its in the right spot. Its setup the same as the pictures on the QTP website im not that retarded
Ill try to snag some pictures tomorrow so you guys can see what im talking about
Old Jul 18, 2009 | 12:01 AM
EvoJoeIX's Avatar
i dont get it, if its pointed towards the door how is it hitting. the exhaust should not be that close to the drive shaft. ive have had a cutout in my car before and never has it ever hit or been close to hitting the drive shaft.
are you sure your its hitting your driveshaft? how do you know?
Old Jul 19, 2009 | 12:36 PM
BostonEvo's Avatar
I know its hitting the driveshaft because i can see where it hit the driveshaft , Its hitting the little Hubs.
Is where its hitting.
Old Jul 19, 2009 | 03:43 PM
1d10t's Avatar
make sure your motor mounts are not broken
Old Jul 19, 2009 | 03:47 PM
06MREvo's Avatar
umm...wish picture was a little bigger...I'm about to go do some stuff on my car...ill look at mine while I'm down there and see what the difference is...
Old Jul 19, 2009 | 05:23 PM
EvoJoeIX's Avatar
it shouldnt be able to hit there.... make sure all your exhaust hangers are in and check the motor mounts.
thats a alot of flex it seems like, unless its just the angle of the picture
Old Jul 20, 2009 | 07:23 AM
BostonEvo's Avatar
This is a picture i just grabbed off the QTP website. Mine is a tad bit closer. But yes it does seem there is a lot of flex ill check out my motor mounts today
wbresson
Jul 9, 2022 06:21 PM
antilag_200
17
Jul 31, 2013 05:12 AM
evane
Dec 30, 2008 06:47 PM
rcheung
27
Sep 12, 2008 10:26 AM
bryans2k
21
Apr 13, 2005 12:45 PM
