What is the highest psi you are running on pump gas with fp red on stock motor?
What is the highest psi you are running on pump gas with fp red on stock motor? What are your power numbers?
You do realize that PSI is only a small portion of the equation, right? Shoot, on my stock IX turbo, I could get it to run knock free running 35psi, and 20psi knock free. There is a lot more to it than just wanting to know what psi a car is running at, if that is wha you are using to try and set your car up. Many people seem to come on here and as these types of questions when it is best to only talk about YOUR specific set-up. Some cars like high psi, some cars don't. Its all about you and YOUR set-up.
true ^
ive seen car that run 25 pounds faster , than 30pounds of boost
if im not mistaken dynoflush , had this vid on utube were they raised up the boost on the red from the low boost to a higher boost , and he was suprised the car didnt make more power , just a bit of tq more , and a better spool up , but no major differenece
