over heat after cam install
Old Aug 14, 2009 | 08:43 AM
loosecannon's Avatar
Originally Posted by draconx
hey guys. last night i installed a set of hks 272s on my car. everything went good. car runs normal and all but today while i was sitting i noticed that my ac wasnt blowing cold air anymore so i looked at the temp guage and it was just about at the 'H'. there is NO leaks at all and the only thing i can reallly think of is maybe its the cams i just put in?... it was 106 out today and the car is NOT tuned yet. but i have not been gettin on it at all.
has anyone else had this problem or know whats goin on?..
(yes i checked for leaks and vac. hoses that came off. cant figure it out.)
i'm just making a guess here . you might be having exhaust reversion due to much overlap of the intake/exhaust cam during idle . which causes the engine temp to increase ...
Old Aug 18, 2009 | 11:45 AM
visyoual's Avatar
^^ not sure about this one.. if it was overlap (im guessing you're referring to the cam design itself) wouldnt anyone with identical hks cams have the same issue???
wtf are you talkin about man?.. i didnt pull my radiator hose at all...
and damn here, someone throws a suggestion and this is the response?
Old Aug 21, 2009 | 02:49 PM
Evo8Emperor's Avatar
Ive had a over heating problem also. Best thing I think check in the fuse block under the hood and check the relays. There are three of them. Make sure you know how or get some one else too do it. Make sure that the right ones have power and ground. Using a 12 volt test light is fine. I actually had a bad ground from the ecu. It was grounding it out ever time power went to it and would blow a fuse.
Old Aug 21, 2009 | 03:15 PM
EvolNinja's Avatar
Originally Posted by sgt_petty_210
when you figure out what the problem is, let me know. Im getting ready for hks 272's, and i do not wanna deal with the same problem. besides my bike the evo is my daily driver.
As long as you follow directions step by step, you should be fine. I did mine twice and twice I thought I skip tooth If you mess up, just do the whole timing belt change Just did mine. Not hard at all. Just takes time and patience. Again, follow directions. Maybe read over the HOW-TO twice before doing it would help.
As for car overheat, it could be that you either didn't put it back correctly and miss a tooth like someone said or you miss a connector. Go over everything and make sure it's pluged back correctly. GL
Evo_Goodness
Jul 13, 2017 05:33 AM
freakitgood
Mar 19, 2009 12:13 AM
goofygrin
Jan 21, 2009 09:02 PM
ThEHiTMaN
Dec 25, 2005 09:14 PM
DynoKing
Dec 27, 2003 04:41 PM
