WOT shifting, what does it take?
Old Jul 22, 2009 | 07:01 PM
Evo8Emperor's Avatar
NLTS and the Stock Ecu. Theres no need for anything else. The stock ecu can handle just about anything. If you spend the time in the Ecu Flash forum you can have your car running on speed density no more maf, using NLTS at WOT with your check engine light as a knock indicator.
The list goes on just do some reading
Old Jul 23, 2009 | 05:38 AM
c_penson's Avatar
all you need are two spare tranys and money for repairs, if you daily drive your car you will always have a bad sincro or sleeve busted forks.
or use your car only to go to the track once every 3 months.
Old Jul 23, 2009 | 10:01 AM
20gmr's Avatar
http://www.youtube.com/watch?v=k9N7liGEC-k
Old Jul 23, 2009 | 10:15 AM
BLKCarbonEVO's Avatar
Originally Posted by evo8emperor
nlts and the stock ecu. Theres no need for anything else. The stock ecu can handle just about anything. If you spend the time in the ecu flash forum you can have your car running on speed density no more maf, using nlts at wot with your check engine light as a knock indicator.
+1
Old Jul 23, 2009 | 10:31 AM
l2r99gst's Avatar
Just for clarification, Tephramod NLTS cuts fuel, not ignition. To me this is better, since you don't have fuel flowing in your cylinders for no reason.
Old Jul 23, 2009 | 06:43 PM
c_penson's Avatar
so you rather have no fuel at 30 pounds of boost at the rev limiter.
Old Jul 23, 2009 | 07:40 PM
l2r99gst's Avatar
Not sure what you're getting at, but yes, during a shift I would rather have the fuel cut than spark. It's the same exact thing as if you lifted to shift.
I've used NLTS (fuel cut) for many years in my DSM and now my Evo and it works great.
Old Jul 23, 2009 | 07:41 PM
OhsixIXBish's Avatar
takes a deep pocket!
Old Jul 23, 2009 | 08:09 PM
FX11's Avatar
+1
Old Jul 24, 2009 | 08:19 AM
20gmr's Avatar
[QUOTE=c_penson;7314702]so you rather have no fuel at 30 pounds of boost at the rev limiter.[/QUOTE
It would be better to hae ignition cut, i think it wold hold the boost better and having ignition cut is always easier on the engine.
Old Jul 24, 2009 | 08:55 AM
ny-quiL's Avatar
Originally Posted by srt4evah
Rebuilding them is cheap, $900 isn't bad to get a stronger tranny back from Shep, Buschur, or the other guys doing strengthened rebuilds.
But why would it break if you have something to interrupt timing, like the WOT Box? What's going to fail first in the Evo tranny?
FYI - Its only "cheap" if you rebuild them before they break
Old Jul 24, 2009 | 09:12 AM
srtboostin22's Avatar
x2, i thought i was only going to spend about 1100$ when i sent it to shep.. i wound up needing a new 2nd gear and 5th gear.. while they were there i got evo 8 3rd and 4th.. wound up being 1800$
Old Jul 24, 2009 | 09:31 AM
norcalSRTrida's Avatar
[QUOTE=20gmr;7316318]
x2
Old Jul 24, 2009 | 04:37 PM
AisuShiden's Avatar
Get a dogbox trans and shift without lifting or using the clutch...
or drive like you care about your Evo more than winning some stupid race.
Old Jul 24, 2009 | 05:32 PM
KevinD's Avatar
dog boxes are for race cars and people with deep (VERY) pockets.
NLTS is your answer. don't add any extra crap you don't need, i.e. a WOT box. its just going to clutter up your car and cause problems. the tephra mod is free, works great, and does exactly what you want.
as for breaking your tranny, the 900 is only assuming that its not broken as someone has already said. once you break it, expect to spend double.
if you have any questions about setting up the car for NLTS or tuning, just let me know. austins only a couple hours away
