EVO IX MR not boosting properly...help
Old Jul 25, 2009 | 01:51 PM
ODUB's Avatar
Originally Posted by mitsuclipsegsx
Is the turbo burning oil. Check for shaft play.
Originally Posted by D420mac
yeah Oil is a sure sign. lol
elaborate?
Old Jul 25, 2009 | 09:33 PM
D420mac's Avatar
if your burning access oil it can mean the shaft bearings/seals are leaking which could mean the bearings are shot meaning a non constistant running/ spooling turbo.
Old Jul 26, 2009 | 07:50 AM
ODUB's Avatar
so where should i look for the signs, and what signs am i looking for?
Old Jul 26, 2009 | 08:03 AM
D420mac's Avatar
blue smoke all the time, not black. oil dripping out of the exhaust when starting, oil anywhere. if you have bad piston rings it would do the same as well you can remove your intake piping off the turbo and check for shaft play aswell.
Old Jul 26, 2009 | 08:31 AM
cij911's Avatar
There are several reasons you could not be getting your expected boost curve, what are you using to control boost ?
(1) Stock BCS and boost profile -- sounds 100% stock to me
(2) Boost leak - you will be testing...
(2) hotter weather
(3) blown turbo - unlikely
Your boost curve sounds like the stock boost - factory BCS, etc. If so, you are fine. If you want more boost / power - read about tuning and boost management in the ECUFlash section...
Old Jul 26, 2009 | 09:29 AM
ODUB's Avatar
oh okay...no, i don't have any of that. the car never smokes, and there aren't any oil leaks. i thought you meant internal leaks that weren't easily spotted from outside the turbo/engine.
(2) hotter weather
the car is 100% stock execpt for the catback. i don't want to tune or do anything until i get the car back to stock power levels again. i'll be checking for the boost leak as soon as i get a boost leak tester ordered. i'm still going to change the coils as well. i think it's just time. hopefully that helps.
Old Jul 26, 2009 | 09:45 AM
cij911's Avatar
Since you are 100% stock, your boost curve - 18psi tapering to ~13 psi seems spot on....You may have a small leak, but the factory boost profile is almost exactly as you describe...
Old Jul 26, 2009 | 12:20 PM
ODUB's Avatar
the IX is supposed to peak at 20.1psi and be around 16psi at redline. it used to boost higher than it does now. my gague has always been a little off, but it's never dipped that low at redline before.
Old Jul 26, 2009 | 02:31 PM
MR White's Avatar
I read before that some of the newer Ixs had a different boost profile, one that was set lower to like 18psi
Old Jul 26, 2009 | 03:00 PM
sparky's Avatar
Aside from the various valid reasons which have already been advanced by others, it may be worth your while to look at the following possibilities: 1)Clogged stock catalytic convertor(Yikes, go to a test pipe!)? 2)Wimpy example of the MR DV(crush it!)? 3)Minimal amount of WG spring pressure(increase WG preload!)?
P.S. I find it reassuring that "the smokester"(AKA smokedmustang) has recovered from his harrowing accident(may God bless), and that my ex-archnemesis, cij911(may God bless) is also doing well, and contributing to this informative thread. Take care!
Old Jul 26, 2009 | 03:25 PM
silverguy's Avatar
yea the 9 peak at around 18 and tapper down to like 13-14 are... mine did until i went cobb
Old Jul 26, 2009 | 03:30 PM
cij911's Avatar
hehehehe, go sparky!
Old Jul 26, 2009 | 04:12 PM
huevosrancheros's Avatar
t bolt clamps are the evo's best friend. Get some samco silicone couplers and hoses and get rid of the crappy stock rubber pieces, they dry out and split. You can get some new vacuum lines from your local auto store.
these threads can better inform you
https://www.evolutionm.net/forums/ev...e-routing.html
https://www.evolutionm.net/forums/ev...at-tool-6.html
Check out post #85 (useful pic) (I also found summitracing.com to have the most affordable tclamps)
Old Jul 26, 2009 | 09:18 PM
dank420's Avatar
it may possibly be burning oil due to its old age. a stock turbo with some decent miles isnt too hard to find. to buy of course
Old Jul 26, 2009 | 10:36 PM
ODUB's Avatar
mine is about as old a IX as you can get. i got it in October of 05 as soon as it came off the truck. First MR they got in houston.
mine has never been that low before.
