guys...HTA GT3582 or HTA GT3586
hi
I want to run one of these turbos but I don't know yet what's the different between them and how much Whp can i get from hta gt3582 and gt3586..how about the spool with 2,3 hks stroke,,,,,
is it around 4000 rpm ..
infact i need 480 whp on pump gas 91 and 620 whp on c16
really depends on an assortment of things...cams, compression, timing. etc...
on a stroker and 6262 (similar to HTA35), i see 23 around 4300.
if you want the ultimate setup...
i'd rock a 2.3L w/ the hta3582 on a twinscroll housing/manifold setup, and rev it out to 8k +/- 200rpm
700hp and wicked fast spool up would be an all around hard to beat setup, imo.
are you running a twinscroll setup?
no, i wish though.
precision does not offer twin scroll housings for the 6262's (1mm larger turbine wheel than the standard 35/HTA series, so i cant just swap the housing)
edit: just noticed you're 2.3+HTA82. how you like it, and when are ya seeing full boost?
i just got my 2.3 hta86 setup tuned. it gets 20psi around 4000rpm. and hits 30psi at 4600 i think. at 30psi it ran 10.90 on crappy tires. the hta82 only spools 200-300 psm faster than the hta86. you would never even notice the difference. but you WILL notice that extra 50hp!
get the hta86, cause if you get the 82 you will be wanting the 86 in no time. im already regreting not getting the hta88!
FWIW, I get 20 psi at 4000 rpm with a 2.0L twinscroll HTA3582, which is about what one gets with a 2.3L open HTA3586. Unless the 2.3 driver turns the wick far up enough to eclipse the maximum of the faster spooling turbo (somewhere north of 600whp), his displacement advantage amounts to somewhere between zero and peanuts. Neat how that works, isn't it?
Spool also depends on the turbine housing right? Ted B, which housing are you using to see that kind of spool on a 2.0L? t3 or t4? ive been looking into these turbos as well and also debating about 2.3L.
