best recirc valve.
Old Oct 10, 2003 | 09:54 AM
ducaticorse's Avatar
best recirc valve.
I've got the new forge, and it looks as though nothing can be done about the fluttering/stumbling at partial release of throttle. This unit will not be staying in my car. So I need to replace it with something that has been tested and proved reliable. What's out there that fits my requirements?
Old Oct 10, 2003 | 10:35 AM
Fireball's Avatar
If you don't want the fluttering, just reverse it. I've heard it backwards and it just has a woosh to it.
Old Oct 10, 2003 | 10:58 AM
Jonasan50's Avatar
Myself and 2 other friends of mine have the Greddy Type-S, and none of us have problems with it... Sounds great too... Although, another friend has the Forge and his is having the same problem with the fluttering... Even with a lighter spring...
Old Oct 10, 2003 | 11:24 AM
Fireball's Avatar
Why is fluttering a problem?
Old Oct 10, 2003 | 01:01 PM
The car jerks back and forth because of the fluttering, not because of the noise, but what ever is making the noise. It is a very bad thing. I wouldn't care if it was just the noise, but when ever you hear the noise, the stumbling occurs, and that is bad.
Old Oct 10, 2003 | 02:14 PM
Fireball's Avatar
I have the fluttering sound when I lift off, but my car never jerks.
Old Oct 10, 2003 | 02:22 PM
I did a search. and there are others that have the same problem as I with this valve, I guess you're lucky. What intake ru running?
Old Oct 10, 2003 | 03:22 PM
5StarSuzuki's Avatar
In Timeout
My Buschur intake will be here monday...As soon as I get paid next month I'm buying a Buschur IC pipe with a 1G Bov. Although if you have welding skills just call adam at Z1 and buy the bov w/ the flange. (You do have to weld the flange on) Its under 50 bucks and its better than the forge for 180...
Old Oct 10, 2003 | 03:33 PM
Fireball's Avatar
Buschur. What do you have?
