help
Old Jul 26, 2009 | 11:06 AM
jdmsego's Avatar
help
i just got a new tune after my new turbo set up and made 360 pump gas at 24psi on an mustang dyno. but now when get up near 5000 or 5500 rpms i feel a cut back almost like a misfire but its not that, i was wonderin if this could cause im runnin the stock injectors cause my tuner told to get bigger ones and i could make more power
Old Jul 26, 2009 | 11:57 AM
Evo8Emperor's Avatar
Do you have the knock cel enable through tephra mods ? I would say its knocking. It might not be knock but the knock sensor could be picking up noise under the hood.
Old Jul 26, 2009 | 12:00 PM
FedEvo8's Avatar
Is your ECU pulling a code? You might want to pull your plugs and inspect, also regap to 0.22...
Old Jul 26, 2009 | 12:32 PM
evolved0414's Avatar
Yea, I had the same problem before...
It ended up being the plugs. And I agree with fedevo, gap them to .22
Old Jul 26, 2009 | 02:15 PM
1d10t's Avatar
gap to .024"
.22 is almost 1/4"
Old Jul 27, 2009 | 03:02 PM
jdmsego's Avatar
ok guys ill try that thanks for the help
