MR 6 speed made stronger?
Look i've come to realize the TRE will never have the gearset out. Not only that, but if they did have it out, you wouldn't be able to get ahold of him to get it put in. Ya sure if your a friend or a relitive you could, but since i'm neither....and i have a 6sp MR tranny.... i guess i have to do the swap to a 5ver.
Depends how much power your planning on throwing at it. Oil coolers help yes, but the problem is that the gears are crammed in the same size housing as a 5sp, so inherently there thinner and weaker. Oil coolers will help prolong the inevitable (if your running big power) rule of thumb; you should be safe running under 350WHP.
There are straight cut gears available for the 6 speed too. Just found this out today from a guy at a Nissan shop called Specialty Z
Might be a lot of gear whine for us daily driver folks, though.
http://www.ppgearbox.com.au/page.asp...1&productid=48
I have a 9 MR, with a six speed. Converting to a 5sp, if you have to swap the gears why not make it stronger. It's a good trans for "lower power level" evo's but they don't hold the power. If you don't believe me start pushing 450+ whp and see how long your 3-4th last.
I've been down that route of looking for gear sets, you know what a Quaife gear set is worth? it's like 6k, 6 ****ing grand + for what? so you can keep the 6th speed in your trans (ok theirs more to a dog engagement box then that, but it's not the point) most of the other guys won’t be far off. IF you have 6k to through at a trans then by all means, but to me I’d rather spend that on a bigger turbo set up.
IMO Shep trans, good for 650WHP get duel syncros on 1st and 2nd your good to go/.
Also take what you read with a grain of salt because half the people on this site get their statements from a friends friends dogs uncle cousins mechanic. Most have no experience with what they babble about. Find out what your goals are realistically and go from there.
