Boost problem...
Old Jul 27, 2009 | 03:51 AM
RallyFan07's Avatar
Boost problem...
I have a problem with my EVO IX (specs: stock turbocharged, full 3 inch exhaust, cosworths M2 camshafts, ECU flash, AVCR)
Problem is boost leak after 6000 rpm from 24.5 psi to 14.5 psi to 8000 rpm…..before boost stay about 21-22 psi at 8000 rpm
I check:
- All piping and intercooler – no boost leak
- changed turbocharged to new
- check exhaust and intake manifolds
- changed spark plugs
- changed ignition coils
- changed MR BOV
- check camshafts, springs, mivec, belts
Please help, I don’t know were I must finding...
many thanks
Old Jul 27, 2009 | 11:03 AM
sparky's Avatar
Is the AVCR an electronic boost controller device? I think it is, but I am not sure. I was wondering just how you are controlling boost. Sorry for the newbie question.
You mention that you´ve changed to a new turbo. Is it a new stock, factory IX turbo, or an altogether different turbocharger?
Old Sep 2, 2009 | 03:05 AM
RallyFan07's Avatar
yes, correct AVCR - electronic boost controller, but I try drive with out AVCR and have some problem wiah boost leak after 6000 rpm
my turbicherged I changed to new stock factory IX.
any more thoughts guys?
Old Sep 2, 2009 | 04:31 AM
Fast_Freddie's Avatar
Veteran: Navy
EGR hoses, throttle body shaft seals... but you need to do a proper boost leak check not just check the IC piping...
Old Sep 2, 2009 | 04:39 AM
JakeTheVIII's Avatar
Sounds like the snorkel syndrome with the stock intake tract, are you using the stock intake?
It's not a boost leak if it doesn't do it throughout the rpm, it's not like it would bust a leak at only 6k+rpm. There's something else wrong with the tune/boost controller/something else.
Old Sep 2, 2009 | 06:03 AM
Veteran: Navy
Actually this is possible... I was leaking out of my lower IC pipe at the J-pipe and it wouldn't pop off it would just leak boost real bad... but you didn't notice until about 15 psi of boost... However the sock snorkel is a big possibility also.
Old Sep 2, 2009 | 06:13 AM
yes, it's possible to have a leak emerge at a higher boost level, but it's not dependent upon the rpm. If boost leaks @ 15psi, it will do it at 2000rpm or 8000rpm.
Old Sep 2, 2009 | 12:00 PM
mplspilot's Avatar
replied here http://www.tuningevo.ru/newforum/ind...6&#entry254186
Old Sep 2, 2009 | 12:50 PM
scheides's Avatar
EvoM Moderator
Igor, you speak russian? Well your name is Igor... :P
Two points:
-boost taper is normal on the stock turbo
-do a boost leak test to make sure there are no leaks anywhere in your intake tract.
Old Sep 2, 2009 | 01:17 PM
mplspilot's Avatar
yep i sure do
Old Sep 2, 2009 | 01:39 PM
scheides's Avatar
EvoM Moderator
And here I thought you were scandinavian.
Old Sep 2, 2009 | 01:55 PM
mplspilot's Avatar
Meh, close enough
