greddy type s help
Old Jul 27, 2009 | 10:51 AM
03evo8kevin's Avatar
greddy type s help
in all my bov experience which isnt much but enough there was only 1 place to hook up a vacuum line and i just got the type s and the is one sticking straight out and one angled down which is which and what? any diagrams on how to install it?
Old Jul 27, 2009 | 11:03 AM
EatSleepBoost's Avatar
leave the one in the middle that is angled down alone. put your boost source to the top nipple.
Old Jul 27, 2009 | 11:12 AM
well i read this but cant quite understand it im not well with comprehending reading im more of a hands on gotta see it to understand kinda thing but here is what i read
"The small hose you removed from the stock BOV must be connected to the larger nipple on the anodized cap (closest to the adjustment screw.)
(Note: This connects to the intake after the throttle butterfly and will pull vacuum when the throttle is closed)
The smaller nipple on the cast aluminum body of the BOV may be spliced into the turbo outlet pipe or into the line between the turbo and wastgate actuator. Use the T-connector supplied. This connects to pressure even when the other line has vacuum. This will activate the BOV faster by applying pressure under the valve seat.
The smaller nipple may also be left unconnected. The BOV will operate slower and more quietly. I did not test this mode." and i got it from this website http://herpetology.com/dsm/bov.html
Old Jul 27, 2009 | 12:20 PM
bump? any help here?
Old Jul 29, 2009 | 09:41 AM
bump!
Old Jul 29, 2009 | 10:39 AM
EvoDom's Avatar
get rid of the greddy and leave the stock one.
or do what EatSleepBoost said
Old Jul 29, 2009 | 09:03 PM
DIDYSIS's Avatar
Ahh, do what you want, I am on my 4th BOV for fun, thats what it is just fun. Good luck Let me know when you want to buy an HKS that is setup like a stock BOV.
leave the one in the middle that is angled down alone(don't hook anything to it). put your boost source to the top nipple.
Other note, use thread tape on the top adjustment screw so it wont leak.
Old Jul 30, 2009 | 10:37 AM
well i really wanna have both hooked up for faster response so any ideas on how to do it
Old Jul 30, 2009 | 10:51 AM
Smike's Avatar
http://evomoto.com/tech_info.php?tPa...ec7f29e7985d28
Old Jul 30, 2009 | 11:03 AM
well that half helps i knew how to do that part already its the lower vaccum port i wanna know where and how to hook up even tho evry1 says leave it alone i want it hooked up
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
the type S in my experience is not very evo friendly if ur gonna be doing any boost past 24 ish psi. maybe less. i have seen 2 evos with the type S just leak once they get into the 20's and i am not knocking on this bov cause its one of my favorites, the evo just doesn;t always work out with it.
Old Jul 30, 2009 | 11:05 AM
im running between 16-18psi so i think im good it also has the single spring mod
Old Jul 30, 2009 | 11:21 AM
if ur gonna stay down there then u should be ok. i suggest what it says to do on the evomoto site. i have never been steered wrong there.
Old Jul 30, 2009 | 11:48 AM
l2r99gst's Avatar
The bootom nipple is for a boost only source. If you connect this, you don't have to do any single spring mod or anything like that. I used to run a Type-S on my DSM. It worked great and held boost great. It works much better with both nipples correctly hooked up...much faster response and you can have a larger preload to begin with to help with holding higher boost better.
Also, as somone pointed out, use some teflon sealant/tape on the top adjusting screw as this BOV leaks from there. After I sealed mine I pressure tested it to well over 30 psi with no leaks.
Old Jul 31, 2009 | 08:08 PM
thats almost 100% the info im lookin for now i just need either really good details on how to hook it up like that or pictures on how wuld b great
