ATF SPIII fluid
Old Jul 28, 2009 | 09:00 AM
EvolNinja's Avatar
ATF SPIII fluid
I tried looking through the manual to see what fluid I should put into the reservoir that reads ATF SP III Sp. Diff Fluid. I'm thinking it's the ACD reservoir but not sure. Can someone help with that? Thanks
Old Jul 28, 2009 | 09:55 AM
sti.this's Avatar
Definitely the ACD reservoir. Ive been putting Dexron 3 ATF in mine. Just make sure you check the level when the car is cool. Right after a drive, it will appear low but return to normal after a little while.
Old Jul 28, 2009 | 10:02 AM
kimletrim's Avatar
Registered User
In the Evo X, its also used for the AYC near the rear diff.
Old Jul 28, 2009 | 10:54 AM
EvolNinja's Avatar
So would that be the Diaqueen fluid? I try to dip some out and smell it. They don't smell the same
Old Jul 28, 2009 | 10:57 AM
kimletrim's Avatar
Registered User
No...the Diaqueen is used for the transfer case and rear diff.
Old Jul 28, 2009 | 10:58 AM
alan678's Avatar
They shouldn't look the same either...
Old Jul 28, 2009 | 11:13 AM
kimletrim's Avatar
Registered User
They don't taste the same either!
Chaser_41
Jan 8, 2016 08:45 PM
NY Evo
Apr 12, 2015 05:28 AM
FSD
Nov 23, 2014 06:10 PM
Blue Evo 8
12
Mar 4, 2013 11:13 PM
sk8elenex92
Jul 19, 2010 06:28 PM
