What can I use to remove the stock lifters from the evo head?
Old Jul 28, 2009 | 09:53 PM
dipsetinallday's Avatar
Old Jul 28, 2009 | 09:56 PM
MasterNater's Avatar
You don't actually need a tool to remove them. Just pull them out with your fingers.
Old Jul 28, 2009 | 10:43 PM
Evo8luva's Avatar
if they wont come out with your fingers, use a needle nose pliers with a shop rag so you dont scratch them
Old Jul 28, 2009 | 11:05 PM
is it possible for the cam lobe to be in the way, when trying to remove the lifters if so how do i get it to move? Also do i need a special tool to decompress the spring to be able to remove the lifters?
Old Jul 29, 2009 | 12:39 AM
xRoguex's Avatar
uh... it sounds like you shouldnt be any where near the inside of your head like you are...
You turn the cam to get the lobes out of the way.. your rockers should already be off.. and just.. yeah..
Old Jul 29, 2009 | 06:50 AM
What is the easiest way to get the cam to move?
Old Jul 29, 2009 | 09:27 AM
barneyb's Avatar
There's methods where you pry the rockers off and back on. I don't like all that prying so I just pull the cams.
Old Jul 29, 2009 | 10:15 AM
mini_evo's Avatar
what can i use to remove the stock lifters from the evo head?
what is the easiest way to get the cam to move?
Originally Posted by xroguex
uh... It sounds like you shouldnt be any where near the inside of your head like you are...
this!
Search the "how To" forum, you should find some info there...........
Old Jul 29, 2009 | 11:21 AM
xRoguex's Avatar
That big bolt at the end of it...?
Hope your at TDC.
Old Jul 29, 2009 | 09:01 PM
DIDYSIS's Avatar
pull :-)
Old Jul 29, 2009 | 09:04 PM
DDATuned's Avatar
Disaster.
Old Jul 29, 2009 | 09:17 PM
Blackened Sky's Avatar
zip tie your cam gears and pull the cams off
Old Jul 29, 2009 | 10:21 PM
xRoguex's Avatar
Originally Posted by Remy
Disaster.
Old Jul 29, 2009 | 11:47 PM
Fast_Freddie's Avatar
Veteran: Navy
This is a nightmare in progress...
Old Jul 30, 2009 | 01:02 AM
xRoguex's Avatar
Redneck's famous words...
hey guys -- watch this!
