100% Injector Duty!Rewire Walbro?
Old Jul 29, 2009 | 11:03 PM
aguita's Avatar
My injector duty is at 100%...I dont want to upgrade the inj right know, My question is if I rewire the fuel pump should this fix the issue??
Will I need to retune??
also does anyone know what I should get to do the rewire?
thanks
Old Jul 29, 2009 | 11:45 PM
Fast_Freddie's Avatar
Veteran: Navy
I would upgrade the injectors if you are at 100% duty cycle anyway... even if you rewire the fuel pump you will most likely still be mid to high 90s for duty cycle...
Old Jul 30, 2009 | 09:11 AM
aguita's Avatar
any other inputs???
Old Jul 30, 2009 | 09:21 AM
scheides's Avatar
EvoM Moderator
How much over 100 are you? I ran mine out to 128% IDC w/o an issue Of course, I upgraded later.
Old Jul 30, 2009 | 09:24 AM
Kracka's Avatar
You can safely take the stock injectors to 115% IDC. EvoScan doesn't show true duty cycle. I took mine to 119.5% before I started having issues.
Old Jul 30, 2009 | 11:31 AM
aguita's Avatar
oh I forgot this is what my PFC is showing on the commander!
Old Jul 30, 2009 | 11:44 AM
leecavturbo's Avatar
if your lean at the top and can't get anymore duty then you need to do something!
Old Jul 30, 2009 | 03:26 PM
aguita's Avatar
I was lean b4 the pump on the upper revs but if I remember my afr on my last tune
Were ok, ill post up my dyno graph to show the afr
Any other suggestions?
DSMolition
Jul 28, 2015 11:25 AM
dbr
Oct 6, 2013 03:18 PM
xXANCHORMONXx
Apr 18, 2013 11:34 PM
aguita
May 25, 2009 11:50 PM
redralliart04
04-06 Lancer Ralliart How To Requests / Questions / Tips
95
Sep 20, 2008 12:04 AM
