should i put this forge DV on...?
Old Nov 4, 2004 | 11:46 AM
  #31
VTECH8TR's Avatar
Originally Posted by smp3000
Awesome, I'll try the yellow spring tonight.
If you have any problems pm me. I can also give you my # if you have Q's .
Later
Old Nov 4, 2004 | 01:47 PM
  #32
Noize's Avatar
EvoM Administrator
Originally Posted by VTECH8TR
Noize,
I have to disagree with you here as you definitely had it installed wrong or had the wrong spring in place. I have the same valve and am holding 22 psi with NO problems. Also part throttle situations are PERFECT in every situation and gears.
Its not rocket science, friend. Although it would be easy to orient it wrong because the vacuum line needs to point forward instead of up (to get the piston pointed to the correct place), it still has partial throttle surge that borders on ridiculous. At WOT, it is perfect, its mainly partial throttle fourth and fifth gear from 3-4psi of boost. I tried every spring/shim combo, and I've concluded that the Forge DV just absolutely sucks (Do a search, several other members have found the same to be true). I replaced it with an MR BOV which holds 25psi with ease and does not surge at all. I'd love to sell it!
