Heat Barrier Intake Manifold Gasket
Old Sep 5, 2009 | 05:29 PM
SPECJUNK's Avatar
How much are the actual temps affected by reduced intake manifold temps.......honestly from my understanding the air in the manifold is moving.....and it is moving crazy fast......so can that air heatsoak from the manifold?
Old Sep 5, 2009 | 05:33 PM
Gary@MellonRacing's Avatar
maybe people that have installed it can tell us ,
Old Sep 5, 2009 | 06:03 PM
Steve93Talon's Avatar
Originally Posted by gfng
were can i get info , on people blowing them up ????
You have to be a member to view DSMlink forums, but here's a pic.
Old Sep 5, 2009 | 07:19 PM
vwjeff's Avatar
I have 1 with 0 complaints so far, I got it from AWD Mike. We will see what it looks like soon after being on for over a year!
Old Sep 5, 2009 | 07:24 PM
Evo8Emperor's Avatar
Are the people running it still using a oem gasket against the manifold just in case ? I have Ive been waiting to put on just haven't yet.
Old Sep 5, 2009 | 09:02 PM
Erik@MIL.SPEC's Avatar
We have been working on sourcing a phenolic that has a melting temp of 600C, which is far superior to the plastic ones that dominate the car industry. This is military grade stuff, so if we do bring it to market, it will be way more expensive. It should be more durable, and hopefully won't have EGR blow-outs like some.
Old Sep 5, 2009 | 09:03 PM
OUCH
thanks man i guess that u can try to make power by avoiding the heat , but u can loose so much more when it gets a huge leak
i think id rather stay with my heat
Old Sep 5, 2009 | 09:08 PM
Blue Evo 8's Avatar
If you can bring it to the market, then people will come in droves to buy it
keep us updated
Old Sep 5, 2009 | 09:36 PM
keep us updated
Well, it may cost up to 3 times as much as existing gaskets. We'll have to see how things pan out...
Old Sep 5, 2009 | 10:26 PM
URBANRCR's Avatar
Weve been using a gasket similar to what milspec has described on our purpose built porsche race cars and our somewhat more "serious" street cars.I have not used any of the gaskets offered to the Evo community, but in our case with the porsches it did lower temps a good bit.
Old Sep 5, 2009 | 10:28 PM
dsm25psi's Avatar
do u have any right now? i kinda need one asap for my new manifold
Old Sep 6, 2009 | 07:26 AM
SPECJUNK's Avatar
where are you seeing lower temps. Colder air temps just befoe the valve, or are you seeing a cooler intake manifold? The phoenalic material is real messy to cut, I would probably look at cutting it with a mill over a laser.
Old Sep 6, 2009 | 07:47 AM
cij911's Avatar
What are you using to log manifold air temps ?
Old Sep 6, 2009 | 06:46 PM
URBANRCR's Avatar
Motec.
Old Sep 6, 2009 | 07:04 PM
TommiM's Avatar
wouldnt the phenolic gasket get heatsoaked after a few drag runs or a few laps around the track, to the point where it becomes just a spacer for your IM?
