What broke in my Tranny???
Old Aug 1, 2009 | 08:30 AM
BLKCarbonEVO's Avatar
So pretty much like the thread says. My tranny seems fine in all gears but 3rd and 4th. If you are shifting into 3rd or 4th it feels like you are "trying to stir a vat of peanut butter!" It goes in smooth with no grinding It just seems really stiff. What does this mean. Don't tell me "it's F'd up" I think i figured that out myself. But let me know what you think may be wrong. If it matters I have the POS 6speed
Old Aug 1, 2009 | 02:49 PM
bbyevo8u's Avatar
Old Aug 1, 2009 | 02:56 PM
Thanks bud
Old Aug 1, 2009 | 02:59 PM
E VOL IX's Avatar
shes done hommie...
Old Aug 1, 2009 | 03:07 PM
Originally Posted by E VOL IX
shes done hommie...
ya that makes 6speed number 2. Now to the 5speed
Old Aug 1, 2009 | 03:50 PM
bbyevo8u's Avatar
could be your under hood shifter bushings that are either shot or need to be lubed!
your tranny is not gone lol
Old Aug 1, 2009 | 04:44 PM
sho669's Avatar
5spd is deff the way to go I had shep rebuild mine about 6 months ago. had him do the evo 8 3rd and 4th swap, make sure you have that done! made a huge difference at the track!
Old Aug 1, 2009 | 04:55 PM
T_Jochum24's Avatar
Could be a syncro issue
Old Aug 1, 2009 | 04:57 PM
gregrego's Avatar
does the 5 speed bolt right up with no hassles to 6 speed cars? Do you require a new ecu? or can it adapt?
Old Aug 1, 2009 | 06:02 PM
94AWDcoupe's Avatar
The problem is internal. The slider for 3/4 is cracked. If you continue to drive it I suggest skipping 3/4. if slider breaks apart you will have a meat grinder on your hands. This is common problem with 6 speed. The slider is thin and easy to crack.
Old Aug 1, 2009 | 06:07 PM
grizly3610's Avatar
this same exact thing just happend to me! I want to get the shep 5 speed but dont have the 3G's to spend right now. How do i check the under hood bushings?
Old Aug 1, 2009 | 06:35 PM
gregrego's Avatar
Open your hood, remove your battery, and tray i think and they are underneath, I have a small battery so its easy to find them.
How many miles on your guys's cars? You guys do anything odd to make this happen?
Old Aug 1, 2009 | 09:35 PM
I have 30k, but its my driving that breaking the tranny. I also have quite a bit of tq. The tranny can't handle my aggressive driving.
Old Aug 1, 2009 | 10:18 PM
gregrego's Avatar
oh, ok! I'm pretty stock, and i "granny shift, not double clutching like I should"
Old Aug 2, 2009 | 04:17 PM
grizly3610's Avatar
Mine has Just under 30k on it. Is it exspensive to get the slider replaced? Or should I just drive it till it breaks then rebuild the whole thing?
