O2 Dump Questions
you shouldn't have anything coming out of the dump tube at idle. if you used the stock gasket then that is probably your issue. i never had any come out of mine at idle, only under hard boost. could be a wastegate issue also...
To the OP:
With my dump I can feel some exhaust gasses escaping. I did use the OEM gasket however so I pretty much knew some was going to get out. I dont believe its an issue however I would love for others to shed some light on this subject.
I put the stock gasket on when I first installed mine and I had some exhaust gases coming out of the dump tube...I took everything off and reinstalling only using the spray on copper gasket...no leaks and its been on there for almost a year...I really enjoy my 02 dump...quiet while normal driving and sounds great at WOT and good power increase...You also may need to tighten you wastegate too because my flapper was open a little bit after installed everything...
WTB[Northeast]: O2 dump housing
Nespeed
Jun 7, 2016 12:58 PM
WTB[Northeast]: Looking for a hood dump
silkey00
Nov 5, 2015 09:37 AM
[WTB] Thru the hood o2 dump
Remmz
Oct 24, 2015 07:37 PM
