Help - Removal of rear O2 sensor and routing of WB wiring
My wideband was plugged into the position my rear O2 should've been and it reached without issue I had the evodave lightmod ashtray gauge pod holder though. I've since had a bung weded into my DP so my wideband is more accurate. Pushed the O2 harness up through the hole and underneath the carpet on the passenger side.
Do you really have to grind? How good does the grommet fit back on if you grinded away metal??
I am also using the AEM and I hope it fits my steering column gauge pod from the passenger side floor drain.
Just get a bung welded on o2 down pipe. And by the way, YOU WILL NEED TO GRIND ON HOLE ON FLOOR BOARD FOR o2 SENSOR TO FIT THROUGH. Just a tiny detail people seem to forget about.
I didn't have to grind anything on the car. I just ran the small end through the whole and cut a tiny hole in the grommet for the small end to go through. Sure you have to pull through more wire but it's better than grinding on your car...
On a side note what are you guys tapping into for power?
RA11226
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
mrwickd123
30
Feb 20, 2019 09:29 PM
EvolutionRacing
Apr 6, 2016 10:29 AM
fi8tzer0
Nov 23, 2015 11:15 PM
