Vacumn Hoses
Old Aug 5, 2009 | 06:27 PM
adamgetem's Avatar
Vacumn Hoses
Ok so im in the middle of doing my rebuild and while im at it i want to replace all the vacumn hoses, because before the motor blew i had a boost leak that i pretty much pinpointed to some of the hoses.
Now my question is can i just go down to the auto parts store and get some vacumn hose of the right size and cut it to length or do i need to replace them with OEM hoses?
Old Aug 5, 2009 | 07:18 PM
PWevo's Avatar
As long as they're quality hoses pick some up. Don't have to be oem hoses.
Old Aug 5, 2009 | 07:26 PM
FQ-300's Avatar
Most local auto part stores should stock the correct hoses you need without you having to pay the high price for "OEM". Create a list and take it by one of the stores to see what you can find. Good luck. You can also try RussellM here on EvoM, he has the hook-up for "OEM" if you want to go that route.
Old Aug 5, 2009 | 08:28 PM
adamgetem's Avatar
Thanks guys thats what i was thinking, i just remember someone saying when i first got my evo that if you were replacing vacumn hoses that you needed to get the oem ones, because somthing to do with boost pressure or somthing i dont really remember, but thanks thats the answer i needed.
Old Aug 6, 2009 | 04:07 AM
Fast_Freddie's Avatar
Veteran: Navy
That would be the boost pills inside the stock lines coming from the wastegate.
Old Aug 6, 2009 | 04:21 AM
JakeTheVIII's Avatar
Exactly what he said^. That only refers to the section of line from the turbo to the boost solenoid. It restricts some of the air going through there, like a stock boost controller basically. It needs to have that pill in there to run normal. This is only if everything is stock. If you have boost controller of any sort, disregard this.
Old Aug 6, 2009 | 04:06 PM
adamgetem's Avatar
Yeah i knew about the boost pill, i will be running a MBC when the car go's back together. thanks guys for the quick responses.
jameswwt
10
Nov 15, 2011 02:31 AM
Turbo01s2k
Apr 27, 2011 05:32 PM
jameswwt
30
Apr 13, 2011 07:15 AM
tsitalon1
155
Jul 4, 2010 11:37 AM
v-manracing
15
May 17, 2010 10:28 PM
