exhaust sagging and sitting way too low...
Old Aug 6, 2009 | 12:06 AM
4G63kevin's Avatar
Unhappy exhaust sagging and sitting way too low...
delete...
Old Aug 6, 2009 | 11:58 AM
RapedApe's Avatar
Doesn't sound right; gotta see these pictures. If it really is a manufacturing issue, which I doubt... you can go through the hassle of sending it back, or just cut off the hangers, shorten, re-weld. If that's the case, I hope you have a TIG or know a buddy that does.
Old Aug 6, 2009 | 12:18 PM
4G63kevin's Avatar
I'm loading pictures right now.
I'm not so sure either. It might be a manufacturing issue. =/
Old Aug 6, 2009 | 12:34 PM
4G63kevin's Avatar
Pictures uploaded...
Old Aug 6, 2009 | 12:39 PM
hopper's Avatar
Did you install a testpipe/HFC at the same time?
dantegra's Avatar
What Brand is this? have you tried contacting the manufacture?
Old Aug 6, 2009 | 12:44 PM
hopper's Avatar
Originally Posted by 4G63punk
Circled in red is the exhaust hanger not sitting right. If it was bolted on both screws, like stock, the muffler will hit the bumper.
I would reccomend bolting them both up and then looking for adjustment up front. Any small adjustment up front makes a huge difference in back
Old Aug 6, 2009 | 12:48 PM
4G63kevin's Avatar
Ima go out in a bit once its cooler outside and put the second bolt back up on the hanger. this is just the catback. im running the stock cat. i just emailed the seller and he said he'll check out if it was a manufactor defect, because the two hangers seemed pretty narrow. I appreciate your help guys.
Old Aug 6, 2009 | 12:50 PM
hopper's Avatar
Am i looking at this right? There are two bolts holding in the hanger. you removed them and moved the rubber hanger to the right using only the right bolt hole on the left side of the hanger?
Old Aug 6, 2009 | 01:32 PM
4G63kevin's Avatar
yeah. correct.
i just put both the two bolts back on. i think its a tad bit higher than the pictures up there. but still, its not up as high as i like it. i might have my uncle re-weld the hangers for me. im thinking probably one of the hanger was welded in the wrong position... the rubber hangers are kind of stretching with both of the two bolts on the hanger.
Old Aug 6, 2009 | 01:38 PM
Raheelq's Avatar
what kind of exhaust is this ?
Old Aug 6, 2009 | 01:49 PM
AWD_Terror's Avatar
Exhaust type?
Im betting that hanger is not setup correctly.
4G63kevin's Avatar
It's a "generic" brand ='[
Old Aug 6, 2009 | 01:51 PM
nikkadanny's Avatar
maybe thats why.
Old Aug 6, 2009 | 01:57 PM
4G63kevin's Avatar
yeah...?? a buddy of mine got the same one, but his fitted perfectly =[
what im thinking is probably one of the hanger is placed and welded on the wrong spot. the hangers dont spread out much. there is alot of gap on the piping and the chassis where the hanger with the two bolts are. do you guys think a simple welding on those two hangers and a bit of movement will do?
