samco coolant hoses quiestion evo 8 or 9
Old Aug 6, 2009 | 04:14 PM
evo7girl's Avatar
Question samco coolant hoses quiestion evo 8 or 9
ok i need to buy coolant hoses , samco sells evo 8 or evo 9 , arent they suppose to be the same for the evo , i ve seen other brands and they say evo8 or 9 , samco is the only one i saw with specific kits for 8 or 9 ... whats the difference ?????
Old Aug 7, 2009 | 07:21 PM
Spinitch's Avatar
Lower hose is different length
Old Aug 7, 2009 | 08:20 PM
huevosrancheros's Avatar
Evo 9 lower hose is shorter than that of the Evo 8. The upper rad hoses are of the same length.
Old Dec 15, 2010 | 01:08 PM
fasterbater's Avatar
BACK FROM THE DEAD!!!!
Can the 8's lower hose be shortened to fit in a 9 application? Or is the bend in the wrong spot?
Reason I ask is that a vendor has the special color I want in stock for the 8 but not for the 9 and if it's a question of length only, then I see no problem in cutting the lower hose to fit.
Cheers
Old Dec 15, 2010 | 09:26 PM
nnb239's Avatar
Why not try other brands other than samco if they don't have your color?
Old Dec 15, 2010 | 09:29 PM
02sleeper-g's Avatar
he isnt trying to stretch it he wants to cut it but yea that shouldn't make any difference at all just make sure its a nice straight cut so you don't end up with the hose not fitting right.
Old Dec 15, 2010 | 09:31 PM
nnb239's Avatar
Correction to that. On top of this make sure the angle is right
Old Dec 16, 2010 | 06:43 AM
Well gentlepeeps, I can now confirm that an Evo 8 kit will fit an Evo 9 if you trim about 6" off of the lower hose, where the neck meets the radiator. Keep the cut clean and it's a perfect fit.
The only reason I'm buying these is for the colorway, since I already have another brand's hose kit lying around and let's just say that urban camo looks way cooler in a red engine bay than orange does.
Old Dec 18, 2010 | 08:06 PM
BuiltS13's Avatar
what if you have an evo 9 motor with a evo 8 rad? What actually changes the distance? Are the evo 8 and 9 rads different or is it the coolant neck on the motor in a different location?
Old Dec 22, 2010 | 03:59 AM
burgers22's Avatar
The JDM 7 is pretty much identical to the USDM 8, the ECUs are very similar but the Evo 7 has different cat's and has the SAS for mild anti lag.
Old Dec 22, 2010 | 08:41 AM
kekek's Avatar
Coolant neck is longer on the 9 motor. It's 5-6 inches further forward at the top. I plan to cut my 8 hose to fit the 9 motor.
Old Dec 23, 2010 | 04:39 PM
BuiltS13's Avatar
good info, glad its not the other way around so im not forced into buying new hoses right away
DSMdynamic
Sep 21, 2016 07:49 AM
MisUnderStood
19
Sep 15, 2015 05:30 AM
nismo3183
13
Sep 6, 2015 03:39 PM
tonyt
Oct 27, 2008 09:02 AM
t51splbb
10
Feb 27, 2008 10:38 PM
