GT35R rebuild ?
Old Aug 10, 2009 | 12:12 PM
Raheelq's Avatar
GT35R rebuild ?
I've searched and searched and I have not found a definite answer to this question....
Are the GT35R turbos rebuildable ? I think mine is going out, cos the car is smoking slightly in boost and there is some oil in the filter. Compression test came out good. I heard that garett had a thing where you could get a rebuild kit for these turbos, but not sure if its still going on. Any suggestions ?
Old Aug 10, 2009 | 02:12 PM
BoostIsMyDrug's Avatar
The GT series turbo's are not rebuildable. The whole cartridge assembly has to be replaced.
Old Aug 10, 2009 | 08:47 PM
Biggie's Avatar
Are the GT35R turbos ? I think mine is going out, cos the is smoking slightly in boost and there is some oil in the filter. Compression test came out good. I heard that garett had a thing where you could get a rebuild kit for these turbos, but not sure if its still going on. Any suggestions ?
I'm in need of some parts off your GT35R, let me know how much you would want for the whole thing... PM me!
Old Aug 11, 2009 | 06:57 AM
Raheelq's Avatar
Biggie I'll let you know what the outcome is of my turbo. If the shop can't do anything with it and I have to buy a new one, I'll PM you. By the way, what parts do you need ?
Old Aug 11, 2009 | 07:06 AM
TiALSport's Avatar
if there is no excessive shaft play and you are blowing oil the turbo is fine
Old Aug 11, 2009 | 08:55 AM
Raheelq's Avatar
There is no excessive shaft play from what I was told, and the compression test is good across the board. What could it be then ?
Old Aug 11, 2009 | 10:01 AM
Biggie's Avatar
Pretty much the whole thing, it's a long story but I need to source a blown GT35R.
Old Aug 11, 2009 | 12:43 PM
TiALSport's Avatar
4 things it can be:
blow by - but your test came back fine so that's not it
CHRA is on an angle >15*
too much oil pressure - this is what i'm betting
poor oil drain
what restrictor do you have?
Old Aug 11, 2009 | 01:46 PM
Raheelq's Avatar
4 things it can be:
poor oil drain
I have the factory boost solenoid if thats what your asking and a turboXS manual boost controller.
If there is too much oil pressure, how could I fix that ?
Old Aug 11, 2009 | 03:10 PM
TiALSport's Avatar
i'm asking about the oil feed line, do you have a restrictor?
Old Aug 11, 2009 | 03:18 PM
ScorpionT's Avatar
Sounds like too much oil pressure to me, its a pretty common problem.
Old Aug 11, 2009 | 08:35 PM
Raheelq's Avatar
So what can be done to eliminate it ?
No restrictor/restriction
Old Aug 11, 2009 | 10:35 PM
ScorpionT is correct. Your smoke is a result of too much oil pressure. Ball bearing turbos require a lot less oil pressure than a sleeve style bearing turbo does. You need to buy a restrictor to lower the oil pressure before it reaches the turbo.
This should get you going in the right direction...
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Old Aug 11, 2009 | 10:45 PM
Oh, and about the Garrett rebuild...
http://www.turbobygarrett.com/turbob...BBService.html
I was curious so I looked it up.
Old Aug 11, 2009 | 11:18 PM
ScorpionT's Avatar
Here is another link:
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
If for some reason that doesnt fix it (highly unlikely) then get your turbo cartridge replaced.
