More issues....any input appreciated
Old Aug 13, 2009 | 01:59 PM
jyndrus90's Avatar
So my evo just is having more and more issues. Cars a 05 with 59k miles and they wouldnt warranty it because the previous owner put on a boost controller and tbe. I told them to prove these things broke the car and they didnt even wanna talk.
Went to the dealer today and they found out my injector o rings are bad and put i needed a new intake manifold seal. Also that my hub bearing is messing up.
Heres what I'm experiencing, when I turn on the car the ACD system works but when driving for a minute all 3 lights turn on (tarmac, gravel and snow). Could this be related to the hub?
Also after i do a pull in any gear the revs hang and fall VERY slow could this be in relation to the intake manifold gasket??
Takes for any help.
Old Aug 13, 2009 | 02:39 PM
SmurfZilla's Avatar
Are you throwing any codes?
Old Aug 13, 2009 | 05:38 PM
jyndrus90's Avatar
P 0243 and p 0141 I think
Old Aug 13, 2009 | 05:44 PM
xhooniex83's Avatar
P0141 Rear H02S Heater, Bank 1
P0243 Turbo/Sup Wastegate Solenoid A Malfunction
Old Aug 14, 2009 | 10:00 AM
jyndrus90's Avatar
Any one else have any input? The cars also leaking oil by the passenger side but not from the oil pan
Old Aug 14, 2009 | 10:10 AM
gsrboi80's Avatar
Make sure the Boost Solenoid is plugged in even though your using a MBC. As for the oil leak check the lines coming to the oil cooler I've had to replace the washers due to a leak there
Old Aug 17, 2009 | 12:19 PM
jyndrus90's Avatar
evodude32
259
Aug 26, 2015 09:22 PM
SmurfZilla
Aug 11, 2015 10:32 AM
SmurfZilla
Aug 10, 2015 09:03 PM
Frew
Jun 24, 2013 03:46 PM
rawkus
Nov 24, 2010 04:01 PM
