Stock Motor,what turbo?
Old Aug 13, 2009 | 06:12 PM
btownsoccer22's Avatar
So pretty much I'm on stock block and I'm not looking to rebuild it till sometime next year. I don't want a red since I don't have E85 down here. Pretty much no stock frame turbos. I was thinking of the 6262 or HTA35r, just need some help on the pros and cons of both.
I know I"m pretty much playing russian roulette with these turbos on stock block but I will be getting a non-aggressive tune.
Just pretty much wanting opinions
Old Aug 13, 2009 | 06:22 PM
inco9nito99's Avatar
You never stated your goals. Type of driving, fuel you'd run, etc.
Old Aug 13, 2009 | 06:25 PM
lol, true
Uhm I will be running it on 93 pump. Goals for stock block 450-500hp. I street drive and will take it to the track whenever I feel like it.
Old Aug 13, 2009 | 06:42 PM
evo003's Avatar
I think you will be dissappointed in both those turbos on a stock motor. They like way more boost then you should run on a stock engine. But if your going to build the motor within a year or so I'd personally go with the HTA35R
Old Aug 13, 2009 | 08:40 PM
Makinahoe's Avatar
HTA35R for sure. It is a perfect compromist between response and top end for a stock 2 litre...
Old Aug 13, 2009 | 11:47 PM
dambikeracer's Avatar
Stock block; HTA 3076 is good for 450ish and better spool then a HTA 35R.
Old Aug 25, 2009 | 07:17 PM
DragEvo9's Avatar
I would look at an fp red green or bbk.. Personally
Old Aug 25, 2009 | 07:19 PM
06MREvo's Avatar
Originally Posted by btownsoccer22
lol, true
Probably hit 450whp with an FP red...full bolt on car...plus cams...and 93 oct....
boost556
Jun 1, 2017 11:30 AM
asu11
Sep 6, 2016 07:31 AM
Rutherford88
May 27, 2016 04:25 PM
Slo_crx1
Jul 30, 2008 07:46 PM
BizarroEvo
Dec 7, 2007 02:43 PM
